Re: Favorite pan, tool or gadget
I have'nt checked in for a long time, but I have found a tool for slicing fresh mozzarella. Put as large a piece of mozzarella that will fit in a hard boiled egg slicer and press the wires down and you will have very nice, evenly sliced cheese. It woks like a CHARM !!
Good luck,
Jack
This is a sticky topic.
Thanks for the pizza's link......................
Hi all, I would have to say, my fav gadget would be my bread maker. As I have a back injury, kneading dough can be quite a painful exercise, so my little friend the bread maker makes it for me. She does does such wonderful job and I can enjoy the rest of my pizza making :-)
Do you simply brush off the bottom of the cooked pizza when done?
The only time ash is a problem is in windy conditions. You just have to brush more often then.
Dmun,
Like to ask you a question about the ashy floor of the oven. Do you simply brush off the bottom of the cooked pizza when done? Looks like the crust would be gritty all the time.
I am still curing my oven and will soon be diving into pizza making. I thought i read about someone using a damp rag on a long mop handle to clean floor prior to cooking, but would that not cool the floor down too much?
Appreciate any help,
Jim Bob
I use mine bare. They get dirty on the bottom from skidding it onto the ashy surface of the cooking floor. I don't think oil would help. Keep it dry, of course. Some people suggest superfine sanding of the working surface to make pizzas slide off better, I don't think this makes much difference.
On a topic up thread, one of the clinker grabbers went on eBay this week, for 72usd. Too rich for my blood.
Wooden FB Peel
Hi,
I have just bought a wooden Forno Bravo peel from the NZ distributor, David Anderson. (BTW a very nice and helpful guy)
Should I season the peel with oil before use (if so, what sort of oil) or just use it as is?
Tim,
I love those pans. There's something about cast iron and brick ovens.
Would use the rack. Stand may be too large for space
I have added a few items to the FB Store, including a nice pair of long leather gloves, cedar planks, and a commercial pizza cutter (you can remove and sharpen/replace the cutting wheel). You can find it all in at http://www.foronbravo.com/store/.
Here are a couple of photos.
Maver,
What a splendid piece of period iron to use with your oven. If you haven't found one yet, keep looking.
Jim
A picture of the clinker grabber that Jack pointed me towards.
the link in case I attach improperly, 6th photo down, patented in 1903
What is it?
Jack, can you include a picture? I'm still using my garden hoe for the same task, the wood handle is finely charred.
I have a tool that I havn't heard mentioned before. I think it's called a "Clinker Grabber," it was used to remove clinkers from a coal fired stoker furnace. A typical stoker would have a hopper and a screw drive auger that would feed coal into the furnace. The clinker is created by the incinerated coal. I use this tool to add wood to the pizza fire,and I am able to place the log right where I want it to go with no mess. It is also handy to move the burning logs from one place to another. Good luck in finding one!!
Mixing dough with a pasta spoon. I tried this a couple of times after Jim's recommendation to handmix wet dough in the bowl before kneading it on the table. That works, but it's messy. So I started using a pasta spoon and it works well and is easy to clean.
It's one of those "wrong tool for the job" things that works. I can see the hair standing up the back of DMUN's neck.
