Thanksgiving Treats
  • #16
    Re: Thanksgiving Treats
    Originally posted by hodgey1 View Post
    I've been doing BBQ and smoking meats for years, thou I'm not an expert. I just want to say that poultry should not be in a environment of less than 300* without being cured first. If you want to smoke a turkey at low temp you must use a brine with a curing salt "sodium nitrite". I have smoked many turkeys at 300* and brined without a cure and they turn out awesome. Just a FYI.
    Thanks Chris,
    I totally missed the 250 temp in the post. Your advice is dead on about the "pink curing salt" in this case Although, the best turkey that I ever had, was a fully cured/smoked. Actually, it was pretty close to the "best ham" that I ever had .
    • #17
      Gulf,
      Those smoking devices are pretty cool. How did your homemade device work out for ya? is that a saw dust paste of some sort?
      Attached picture is charcoal snake method that I was considering. I figured it might work on a WFO. Although now that I think about it, starting with a cold oven I would probably have trouble reaching and maintaining temperature.......... Makes more sense to have preheated oven. I'm not sure how much heat this method would produce, but I think I give it test run on a Boston butt before turkey day.
      I plan on brining my turkey before hand. Any one have any brine recipes they would like to share?
      Respectfully,
      KB
      My build
      • #18
        Originally posted by Faith In Virginia View Post
        Ryan. I don't want to burst your bubble but unless you have some super duper WFO...I would say I don't think so to your heating schedule.
        So you may want to plan on giving the oven a bit of a kick here and there.
        Oh certainly. The overnight temperature loss is probably going to be the biggest problem. If I can the oven around 525 for bread baking, experience with my oven tells me the rest should work out. I've managed to keep temps >525 overnight before, but not from one long firing, so most likely I'll need to light a quick fire Thursday morning and bake the bread closer to noon.
        My build: http://www.fornobravo.com/forum/f8/3...-dc-18213.html
        • #19
          Originally posted by kbartman View Post
          Gulf,
          All of the pics in my above posts were taken from the internet. The homemade smoking maze/snake was also, and is not something that I have tried.........yet . But I will be doing so very soon. It is not a paste, just regular hardwood/fruitwood saw dust (of your choosing for flavor preference) poured into the container.
          Please give us/me a report on the charcoal snake after you do. It sounds very interesting!
          I'll pass on the brining recipes, unless you want to check this one out on another forum that I'm following.
          I'm sure that you will get some varying and all very great responses to that question .
          • #20
            Charcoal snake was a success. More details later. Attached pictures help tell the story.
            Respectfully,
            KB
            My build
            • #21
              I began the day by making a couple of temporary smoker doors. The outer door is to regulate temperature. The inner to bring the smoke and heat down to surround the meat.
              Started with a oven temperature about 170F from a previous firing. I placed the charcoal around the outside if dome. I lite the end of the snake with hot coals from my chimney starter about 12:30pm. Place the Butt in a roasting pan and placed in oven about 1:00 pm, the oven had climbed to about 220F. The temperature slowly climbed thru the day, reaching about 350F about 7:30 as coals exhausted. I removed the smoker doors and closed oven. I took the Boston Butt out about 10:30pm and let rest and pulled........ Deeeelicious
              Respectfully,
              KB
              My build
              • #22
                Very nice KB! This is the first I've seen this technique used with briquettes at least in the context of a WFO. Nice!
                Chris
                • #23
                  Looking forward to those brine recipes.
                  I think I decided on the method my bird will see on turkey day , although I will try to start the snake with a satuated of temp of about 250F, and stabilize about 300F. I'm cooking a 16.5lb bird, maybe stuffed it. Wonder how long should I cook it? Dinners is at 1:00 pm, birds needs to rest, when should I start?....................... How will you all cook your bird this turkey day?
                  Respectfully,
                  KB
                  My build
                  • #24
                    A 16 lb stuffed bird will take 5 1/2 to 6 hours at 325 in a conventional oven. Our WFO's are similar to a convection oven so they say to drop the temp 25 deg. and start checking about 3/4 of the target cooking time. As we know, all of our ovens perform a little differently. In regard to brines, just google it. There are thousands of them, just pick what appeals to you. My wife likes the citrus flavored brines. We even stuff the bird w/ orange slices.
                    I wish I could give you a definitive answer regarding time/temp/weight but this is my 3rd year and it's still a work in progress.
                    • #25
                      This recipe came to me from a friend from the West Virginia hills who has been using it for years. I can not say enough about how good it turns out. The recipe is simple yet the results are really amazing, juicy and flavorful.
                      One 15-20 lb turkey
                      One cup brown sugar
                      One cup Kosher salt
                      One Large onion diced
                      Additional Kosher Salt
                      Put the turkey in a large enough vessel to submerge, fill with cold water until turkey is sufficiently covered and remove turkey. Add all the listed ingredients and mix throughly. Put a whole "un-cracked" egg into the mixture, start adding additional Kosher salt while mixing and continue adding until egg floats. Remove egg and submerge turkey and keep refrigerated in brine for 48 hours. Remove, rinse and cook at 300* until thermometer read 170* in thigh. The last bird I did was 21lbs and was done in 5hrs unstuffed. The results are to die for!
                      Note/warning! I would not recommend this method with a stuffed bird. Poultry is nothing to mess with at lower cooking temps, if you love the flavor of stuffing inside a bird, cook off all of the giblets/neck and take some of the stock and add it to your stuffing. Also, if you want to slow smoke using this method, add the appropriate amount of curing salt/Prague powder to the brine and smoke at 250* until done. My years of experience and opinion is, don't waste your time curing and smoking a turkey unless you love ham because that what you end up with, and no one wants ham at Thanksgiving.
                      Chris
                      Link to my photo album:
                      • #26
                        Maybe,....... not,.................... "up there"
                        • #27
                          Yeah, I'm w/Gulf! Ham & Turkey for Thanksgiving, Seafood for Christmas Eve, Standing Rib Roast for Xmas Day, Leg of Lamb for Easter & don't forget the red beans & rice for New Years'!
                          Anyway, I digress. Here is my brine recipe that I adapted from Alton Brown. I believe his had candied ginger (way too fancy smancy for me)
                          1 cup kosher salt
                          1/2 cup light brown sugar
                          1 gallon vegetable stock
                          1 tablespoon black peppercorns
                          1 1/2 teaspoons allspice berries
                          1 gallon heavily iced water
                          I also love Coriander with my poultry so I throw 1TBSP Coriander Seeds in as well. Luckily I work in a restaurant and have access to a walk-in cooler which is where I set my science experiment inside my Home Depot 5 gallon bucket.
                          • #28
                            We did a turkey last year in our oven which we got last October. We started the fire a little late and had to get the turkey in while it was "pizza hot" to keep on schedule.
                            Well my hubby stood there for a good hour with the roasting pan in the mouth of the oven rotating it continuously until the skin was golden brown. We put the cover on, kept it half in, half out and would rotate every 15 min or so. It was a 25# brined, stuffed bird. It was done to correct temp. in under 2.5 hours and was by far the best bird we have ever eaten. My technique with the stuffing is to get it really hot in the microwave and stuff immediately before roasting. Screwing up on timing turned out in our favor!
                            • #29
                              Ok so I don't know how I came across this, but it's from this site. I'm going to be following this plan of attack. I posted a few questions that remain unclear to me in the get cooking section of the forums as well.
                              Forno Bravo Community Cookbook
                              Wood-Oven Roasted Thanksgiving Turkey
                              Posted on November 28, 2011 by admin
                              what follows is my treatise on roasting a holiday turkey in a wood-fired oven. this was my first try at roasting a bird in the oven, but the results were pretty delicious, if i do say so. my thanksgiving guests are willing to back me up, so i’ll take that as enough proof that this is a method worth sharing. as with any wood-oven cooking, results may vary. i’m working with a primavera 60 model oven, and this particular turkey was approximately 12.5 pounds. by my guess, the primavera 60 could probably fit up to a 15- or 16-pound turkey, but not much past that. on to the cooking!
                              for the brine:
                              1/2 gallon water
                              1 c kosher salt
                              1 c dark brown sugar
                              2 oranges
                              2 lemons
                              1 tbs whole black peppercorns
                              1/2 bunch fresh parsley
                              2 sprigs fresh sage
                              6 sprigs fresh thyme
                              1/2 yellow onion, sliced
                              1/2 head garlic, cut in half
                              4 lbs ice
                              for the turkey:
                              4 tbs butter, softened
                              1 orange
                              1 lemon
                              2 sprigs fresh sage
                              4 sprigs fresh thyme
                              3 ft (or so) butcher’s twine
                              4 carrots
                              4 ribs celery
                              2 yellow onions
                              2-3 sheets aluminum foil
                              the day before you want to cook, combine all the brine ingredients except the ice and bring to a boil. for the oranges and lemons, use a vegetable peeler to remove the zest and add that, along with the juice from each fruit, to the brine. discard the rest of the fruit. once the brine has come up, remove from the heat to a container big enough to hold your turkey. add the ice to cool the brine.
                              (this is a good tip when doing any sort of brining – instead of waiting around for your brine to cool, always halve the amount of water the brine calls for and make up the rest in ice. a pint of water weighs exactly 1 pound, so it’s always easy to convert volume to weight. so, for example, with this brine we need one gallon of water total. we use half a gallon to steep the aromatics and dissolve the salt and sugar, and then cool it down with 4 pounds of ice: 4 pounds of ice equals 4 pints of water, and 4 pints equals 2 quarts, or half a gallon, of water. done and done.)
                              place your turkey in the brine breast-side down and store, refrigerated, overnight. (another aside: if you don’t have a big enough refrigerator to hold your bird in the brine, do your brining in a cooler. if you’re working in a cold-weather area, just stow away the cooler outside or in an unheated garage. otherwise throw some ice packs in the brine with the turkey, seal up the cooler, and you should be good to go.)
                              the next morning, remove the turkey from the brine and allow it to sit on your counter, uncovered, for at least an hour. this will allow the bird to dry off somewhat, as well as temper, which will make for much more even cooking. meanwhile, get your oven burning. you want a nice hot, but not blazing, oven to roast in. i fired my oven and held it at around 450F for an hour before i put the bird in.
                              to prepare the turkey for roasting, first rub with the butter. apply some to the outside of the bird, and then, using your finger, gently separate the skin from the breast meat to form a pocket. work the rest of the butter under the skin so that it covers the breast meat. slice up the orange and the lemon and insert them into the cavity along with the sage and thyme. next use the twine to truss the bird. i won’t go into yet another long aside on trussing, but i will say that a trussed bird will cook more evenly and will look nicer on the platter as a finished product. go online and you should be able to find a number of illustrated guides to trussing a bird in about 2 seconds. next, roughly chop the carrots, celery and onions and place in the bottom of your roasting pan. if you have a roasting rack , place this on top of the mirepoix and put your turkey on the rack. otherwise, the turkey can sit directly on top of the mirepoix with no ill effects.
                              now, at long last, we’re ready to cook. i put my turkey in the oven with my door thermometer reading about 450F. i also made sure to keep a small stick or two of wood smoldering in the back of the oven at all times to impart a nice smokey flavor to the meat. my finished bird had an assertive, but by no means overpowering, smokiness that everyone loved. after about 10 minutes, i rotated my bird 180 degrees. after 20 minutes, i already had nice color on the skin, so i tented the bird with the foil. this will allow your turkey to continue cooking while minimizing additional browning. if your bird hasn’t taken on sufficient color after 20 minutes, allow it to continue cooking uncovered until it gets where you want it. after you’ve tented your bird, allow it to continue roasting, rotating every half hour or so, until a thermometer inserted between the thigh and breast reads 160F. for my 12.5 pounder, my total cooking time was about 2.5 hours. by the end of cooking, my oven door thermo reading was hovering somewhere around 300F. remove your turkey from the oven and allow it to rest for at least 20 minutes before carving.
                              based on informal polling, this was probably the best thanksgiving turkey my family ever had, so give it a shot and you won’t be disappointed. oh, and don’t forget to make some delicious smokey gravy from the drippings in the bottom of the pan. good luck and good cooking.
                              Link to my oven build on YouTube:
                              http://www.youtube.com/watch?v=Ujb7lqVcSzQ
                              • #30
                                We are invited to friends for Thanksgiving and we decided to cook our turkey today. I had fired the oven for pizza two days ago. The temp today (about 300f) which was a bit lower then the 325 to 350 I wanted for the turkey. So I built a small fire to raise the temp. I pushed the coals to the back and started the turkey cooking. I generally followed the guidelines described at the site below.
                                Barbecue Turkey And Turkey On The Grill: The Ultimate Smoked Turkey Recipe
                                I rubbed a herb and oil mix above and below the skin and rotated the pan every 15 minutes for the first hour. I removed turkey when the breast temp was 160f. Results were very moist and tasty.
                                Link to my build here:
                                http://www.fornobravo.com/forum/f6/3...lly-19181.html
                                Selected pictures of the build.
                                https://picasaweb.google.com/1168565...g&noredirect=1
                                sigpic “In theory, theory and practice are the same. In practice, they are not.” ― Albert Einstein
