Beer can chicken - Forno Bravo Forum: The Wood-Fired Oven Community
Beer can chicken
  • Beer can chicken
    What temp and how long do you cook this? I made pizza's Saturday night, 2 batches of bread Sunday morning, and when I went out this AM (Monday) the hearth was 247 degrees. I know poultry needs to be 180 - but I was looking to slow cook it all day. I may have a pile of ash when I get home tonight.
    TIA,
    Les...
    Re: Beer can chicken
    OK - have the answer (sort of). Had the wife check it at noon - she tugged on a wing and it fell off She took it out and put it in the fridge for tonight. Sooo - at that temp - WAY less than 5 hours. This thing is retaining heat a lot longer than I expected and our night time temps are below freezing. Insulation is our friend...
    Les...
      I've never done slooooowwwwww roasted chicken. I wonder how hot it got in the thigh. Can't wait to hear more.
        I'm thinking 247 degrees. The driest chicken I have ever had. My wife is going to add a couple of quarts of mayo to hydrate it for chicken salad sandwiches. Good thing chickens only cost a dollar a pound.
        Les...
          That's too funny. And to think, I would never have believed that you could bake dry chicken in a brick oven. :-)
            Les, I usually put a pot roast in the next day. That can handle all day cooking...
            I brown a chuck roast and then add a bottle of wine, some carrots, onions and celery. Put it in a covered dutch oven and let it go all day...
            My Oven Thread:
              Drake - what's the temp when you put it in. And all day - something around 8 hours?
              thanks,
              Les...
                IMHO, not enough fat in a chicken to slow roast. I do my beer can chicken at 400* for about an hour to an hour & 15 minutes. You can either use a probe thermometer (160* breast meat and/or 180* thigh), or poke the bottom of the thigh joint to see if you have clear juices running. I've done chuck roasts and boston butts slow at lower temps (<300*) for 8-12 hours in my WFO. Large chunks of fatty meats have a mind of their own. As the fat and connective tissue render, the meat can actually start to cool. This is the plateau, and it can take an hour or two to get past it. A probe thermometer is the ticket to properly judge when they're done. If you want to slice, internal temps should be around 180* if you want to shred or pull they should be 195-200. However, if you want to roast a leaner cut of meat to slice, you need to pick your doneness and cook at higher temps (375-400). So, to review: You cook lean meats at higher oven temps and to lower internal temps for tender results. Conversely, you cook fatty meats at lower oven temps and to higher internal temps for tender results. Hope this helps.
                  Les, What 70Chevelle said is just right. A fatty roast like chuck or a pork shoulder, in the oven around 300 degrees and let the oven decline in temp for the next 8 hours. I usually go to 180 deg internal temp or slightly more on pork roasts. I guess with my pot roasts they could probably come out of the oven sooner, but it does not hurt them to be in there that long.
                  My Oven Thread:
                    Les...
                    Might be good for soup!
                      Maybe if you wrapped the chicken in bacon rind and put it in one of those closed iron pots with a good slosh of wine or something? That could stop it drying out... but maybe 8 hours is just too long for a chicken.
                        I dunno ... I just don't think I'd slow-cook chicken at low temps - anything else, but I'd worry too much about bacteria where poultry is concerned.
                        Sarah
                          I though it might work - failed miserably I had a link to James' video and paid no attention. Watched it last night, I think I will follow his lead next time...
                          http://www.fornobravo.com/video/beer_can_chicken.mov
