Why necessary to clean all coals out for bread? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Why necessary to clean all coals out for bread?
    I understand why I should mop the bare floor for hearth breads, just to minimize the ash on the bottom of the bread, but why clean all the coals thoroughly out instead of shoving them to the side and letting the oven "relax" for a few hours before cooking?
    More to the point, is the purpose of totally cleaning out the oven one of flavor or temperature management?
    Re: Why necessary to clean all coals out for bread?
    Good question - I'm also keen to hear the rationale behind the coal removal process. I did this when I baked bread the last time and it was a disaster as I was unable to control the heat. In future I will scatter a few coals around the inside of the oven (remove most first).
    / Rossco
      It prevents 'hot spots' in the oven
      you should let the oven equalise for an hour before baking. this allow the heat to evenly distribute around the oven.
      if you leave the coals in, the bread near the coals will burn, while the bread further away will not be cooked.
      opening & closing the oven all the time (to move or remove burning bread) is not good for the baking process!
      My 2nd Build:
      Is here
        Thanks for clarifying Mitch - I was probably over simplifying the process in my mind!
        Just a question though - with a small amount of coal left in the oven - would the heat not stabilise to a uniform state? I am talking really small amounts of coal evenly distributed around the outside of the oven - just enough to sustain the heat.
        With the door in place and a small space to allow a bit of air in - would this not be the optimum arrangement to sustain a long bake?
        / Rossco
          It's the radiated heat from the coals that's the problem.
          Though I guess you could shield the loaves with a wall of foil or something....
          but if we're talking about bread - the heat loss over a 40 minute period isn't going to be enough to warrant keeping a heat source in there...IMO...
          Also - on keeping the door ajar - most people when they bake bread will use a water sprayer to 'spritz' the oven - the humidity/steam helps with the oven spring of your bread. they'll do this and then get the door on as quick as possible to lock the steam in.
          Having the door cracked open to help your coals burn would effectively cycle the air in the over and suck all the steam out.
          If you're talking about roasting (meat etc) - well that's a different story...
          My 2nd Build:
          Is here
            Thanks for the update Mitch ... all makes sense now!
            I will definitely be removing the coals from now on, in light of this information.
            Ross
            / Rossco
              There is so much wrong with having coals in the oven with the bread (assuming you are striving to make great bread) that it is hard to address.
              IF you have LIVE coals in the oven you have temperature control problems, your oven is at the wrong temp (very likely both too hot and too cold depending on location), you don't have enough humidiity in the oven to give a good crust, and you are drying out the skin on the bread with the fresh air.
              If you have DEAD coals in the oven the ashes insulate the oven from the hearth and reduce heat transfer from the refractory back to the oven.
              Bread should be baked in a CLOSED oven. This is important because you need humidity to gelatinize the starch in the crust to get a good crust. You won't have any signifcant humidity in an open or fired oven.
              The oven also needs to be at an appropriate temperature. For relatively wet artisinal breads you will want the oven at about 550 to 575, maybe 600 depending on the batch size, your habits, and your oven.
              It is IMPORTANT that the oven be heat loaded. If you have made pizzas your oven MIGHT be loaded - but it might not. Depends on how hot you run your oven. You need to drive heat into the oven - keep the fire big and hot for another 45 minute to several hours depending on your oven design to load it properly. The temp on your hearth will probably be in the 800 to 900 range and the dome well over 1000. Most then remove the coals and let the oven sit for an hour or so to let the heat equalize and for the heat to continue soaking into the refractory.
              After about an hour (again depending on your oven and how hard you stoked it) the temperature of the hearth should be in the 600 range. The dome will be slightly warmer but not hundreds of degrees. At that point you clean the oven well and mop it with a damp (not wet) ash cloth/mop. This will probably drop the hearth temp by about 25 degrees. Loading the oven with bread will drop the temp in the oven dramatically as will spraying it with water to raise the humidity. (The temp may well get below 300 degrees.) You are relying on the heat you drove into the refractory to be released back to the oven to bake the bread. After about 50 minutes the bread should be done (assuming one to two pound loaves in a 15 pound bake (and the oven should generally not be opened in the first half of the bake - preferably not to the end though you will likely need to as you learn your oven.)
              When you take the bread out the temp of the hearth will still be depressed. If you close the oven back up for 15 minutes or so the temp should have dropped no more than 50 degrees or so (i.e. if you started at 575 it should be about 525 or so). If so you can probably do a second batch. if it is below 500 you probably can't reasonably do a second batch. Either you don't have enough oven mass or you didn't pack enough heat into the mass you have or you have lousy insulation or are wet. If the temp is way lower, you probably tried to bake bread in an inadequately heated oven.
              All that said, can you bake bread with live coals or a fire? Sure. But it will be mediocre compared to what your oven is capable of producing.
              Jay
                great post jay - thanks!
                My 2nd Build:
                Is here
                  I dunno. I just pulled a couple of pretty freakin fabulous looking loaves from an oven that still had coals in it. What can I say...10pm, dark, lazy and in my jammies...I am SO not shoveling out no hot crap despite Jay's 100% convincing (and awesome, as usual) testimony. I wanna get my couple of pounds of bread for the week baked and get back to lounging. It's still going to be better than anything I pull out of my indoor oven.
                  My standard MO is to put the door on to kill the fire when I'm done with pizza, so after 3+ hours of suffocating I was down to glowing embers around the edges of the dome plus my still-clean hearth and 500-ish, perfect for what ended up being an odds and ends "dump batch" of white/wholewheat/rye sourdough of questionable but lower than usual hydration (my current method seems to lean heavily towards "dump stuff in until it feels and looks right"). Came out awesome. Prolly not Jay awesome, but pretty good for a lazy butt poseur breadbaker
                    Boy, I sure learn a lot on this forum. Thanks for the info Jay.
                    Maybe there's something going on with my method of frantically sliding my loaves in the oven and putting my ugly (but tight ) door on but I only had to do that once to get ash all over my loaves to get me to clean out my oven now every time. Also, when I sprayed my oven with the garden sprayer to create moisture, the sudden steam made the ash fly too.
                    I completely understand Splatgirls MO and have no doubt I'll occasionally be doing the same thing , I can't explain well enough how nice it was to spend the 2 minutes to clean out the oven, then have a huge, clean canvas to bake in, anywhere in the oven I chose to throw the loaves. If I felt like slamming my oven door on, I didn't have to worry about the pressure moving the ash.
                    I say, leave in the ash and coals for nestling your artichokes into, but try to remove it for baking.
                    My Oven Costs Spreadsheet
                    My Oven Thread
                      Wow, this is my own thread and I totally dropped the ball on it. I need to back and read all this great information.
                      Thanks everyone.
                        Jay,
                        AWSOME, direct, to the point, and in terms that a chickenshzzt non baker like myself understand. ALMOST makes me want to give bread a shot, ALMOST.
                        Just can't break myself of my mantra - I cook, and cook very well; why ruin everthing by trying to bake?
                        A couple more meaningful post like that and some nut in Texas will be getting a knock at his door by some other nut from FL insisting he be taught every thing and any thing about bread baking. Jay can I volunteer to be the breadmakers apprentice?
                        RT
                          Thanks a ton for all the great information. I will certainly try cleaning out my oven for bread once I get the necessary tools (large metal dustbin, perhaps from a converted stop-sign ) and some sort of receptacle, a metal box which I simply having nothing to stand in for yet.
                          However, one thing you said thoroughly confused me...
                          Originally posted by texassourdough View Post
                          After about 50 minutes the bread should be done (assuming one to two pound loaves in a 15 pound bake...
                          Jay
                          First, may I assume that "15 pound bake" means total dough, as in 7 2lb or 15 1lb loaves? Is that what 15 pound bake means?
                          My confusion arises from the fact that the FB bread book says 2lb bread should cook in like 22 minutes and 1lb bread should cook in 12 minutes (p. 10). Do you have any idea why there is such a discrepancy here, more than a factor of two?
                          At any rate, thanks again for the thorough explanation. I'm really excited to try bread and want to do it right.
                          Cheers!
                            I baked bread once when I still had coals in. I didn't like the odd flavor I got. Smoked is good for lots of things, but not bread.
                            I almost never have to go 50 minutes to cook a loaf (mine run about 1.5 to 2 pounds, mostly). Most of them cook in about 20 to 25.
                            This winter, when I was forced to bake mostly inside (I'll post pics later of my oven reclamation, but let's just say that the winter has NOT been kind) I would load the oven with a baking stone on the top shelf and a rack lined with quarry tiles on the bottom and heat it up as far as I can go- about 500. Then I'd put in my bread, steam the oven (hot water in a pan that preheated while the oven did) and set the timer for 10 minutes. When it goes off, I turn the loaves end for end and then I put the probe of my oven thermometer (the kind with the metal cord) in and set the temp for 205- usually it goes off in another 10 to 15 minutes.
                            While I know that it's heresy to poke a hole in my bread that way, it works pretty well, and after the first 10 minutes, the crust is set and I haven't had one deflate on me yet. I just wish I had a thermometer that had a really really long cord on it for using outside!
                            RT, even practice loaves from a novice usually taste better than store bread. If you want to try it, get Reinhart's Bread Baker's Apprentice and read. My sister in law bought it last year after eating my bread and has gotten herself into it! Hamelman's Bread is good too, but I think Reinhart's is a little easier for a novice to read. I think Bread is more like a text book. I also have Whole Grain Breads, but I recommend Apprentice first.
                            you could also try out the no-knead breads. I have a couple of recipes I use for that, it's easy and turns out well. PM me if you want them.
                            Elizabeth
                              Jay
                              Very concise and practical article. Have kept for further reference; oven base just about complete and mouth already watering.
                              Dave Ly
