Is my sourdough starter intoxicated? - Forno Bravo Forum: The Wood-Fired Oven Community
Community Cookbook Recipe Contest
Do you have a wood fired recipe that gets rave reviews from family and friends? Now is your opportunity to not only share it with other wood fired chefs and enthusiasts, but get rewarded, too! Starting June 1 through July 30, 2016 we are holding a Summer Wood Fired Recipe Contest and the winner will receive a $75.00 shopping spree in the Forno Bravo Store.
Submit your recipes through the Forno Bravo Community Cookbook “Submit a Recipe” button. The winner will be based on the number of votes the recipe receives. A link to the recipes will be posted on the Forno Bravo Facebook, Google+, Instagram, Twitter, Pinterest pages and the Forum. To be eligible to win, your recipe must include a photo of the dish being cooked in your wood fired oven.
See more
See less
  • Is my sourdough starter intoxicated?
    Preface:
    I've done wild yeast and/or sourdough many times over the years with good success. My method is generally to start with grapes and a dough-like mix of water/flour... and build it from there.
    Someone just gave me a packet of San Francisco sourdough starter and I decided to experiement. The biggest part of the experiment is that I'm opting to follow the instructions (which, is not generally my style).
    The water/flour mix the instructions recommend is 1:1; much wetter than waht I generally do. After stirring in the packet contents it started bubbling furiously like it should. After a few days I tried making bread, using the provided recipe.
    The Problem:
    The dough never rised. The dough was never baked and never became bread. We had a cold snap and probably it just wasn't conducive to bread rising.
    The Question:
    Now that I've worked (fed and talked nicely to) the starter for a couple of weeks I'm ready to try again. But last night I looked at the starter and there was a thick (1/2 inch) layer of hooch. By the smell of it the starter is both very sour and very intoxicated... and stopped bubbling I stirred the hooch back in to the starter; should I have drunk it instead? After feeding the starter it started bubbling again.
    Re: Is my sourdough starter intoxicated?
    Brian, my sourdough starter acts the same way. I just stir it up and feed it. When you make your bread is the sponge very active? I leave mine out for 12hour's prior to making the bread, I don't get a 2 fold rise but it is bread.
    Les...
      Hi Brian!
      If you had a half inch of hooch your yeast population was depressed. While it can be used successfully to make bread, it is hard to know how long it will take for the leaven to be ready for the final expansion. And, you should expect that it won't be as active as it is capable of - so your bread won't rise quite as much as it should. Not a big deal but when it gets that far past peak I recommend feeding it twice over a day or so before making bread. With a 12 hour feeding schedule it should be much more active after the second feeding and really ready to do bread!
      Good luck!
      Jay
        Stirring and feeding seems to have improved this starter's attitude. It seems to be bubbling normally. Now I have to keep it going for a few more days -- can't bake until the weekend!
          Funny you should mention this - I started a new starter a few weeks ago and on giving it the sniff test recently I notized a very strong booze smell. My other starter does not smell like this at all. Maybe it needs more time or something... or some booze bugs have taken up residence in it perhaps???
          / Rossco
            Alcohol (hooch) is a byproduct of fermentation. If it is in excess (and sitting on top of the starter or if it smells of alcohol) the yeast needs food. Excess alcohol kills yeast so if you have excess the leaven is impaired. That's why it needs (as Brian said) to be stirred and fed. (some people throw the alcohol out - I don't. I keep it for the flavor. Note: hooch is mainly water but there is flavor in it!)
            Fresh, healthy starter won't smell like alcohol!
            Feed it!
            Jay
              That is clearly alcohol abuse - shame on them
              Les...
                Hmmmm perhaps I can make my next starter inside a copper still!!!! That way everybody's kept happy. I think it's called recycling or something!!
                / Rossco
                  I don't know if it my imagination or not, but I seem to see more hooch associated with a wet starter than a stiff starter. I always thought that a wetter starter just allowed the flour settles and allows water to separate (float) more than a firm starter... but I also seem to notice a more alcoholic smell.
                    Hi Brian!
                    I am not sure about the flour settling out though there may be a limit to how much water the flour can hold/contain but yeast definitely grows faster in a wetter medium so will make hooch faster.
                    Jay
                      Hi Jay,
                      As I mentioned before, this is an "experiment" with a pre-packaged SF sourdough starter packet... and the instructions called for a 1:1 water/flour mix. I've never tried a wild yeast or sourdough starter so wet!
                      I think you are right. The yeast activity seems fast and furious after feeding; then quickly seems to stop and drown itself in its own hooch.
                      The day before yesterday I pulled out some of the wet starter and mixed up a stiffer starter. That performed more like what I have experienced in the past. Last night I mixed that into a dough and started that rising in the fridge. That, too, is performing like I expect.
                      So I conclude that you are right -- wet starter makes yeast and hooch faster, but also makes the yeast stop too suddenly.
                      The best news is that the starter smells and tastes great. Now that I know how it performs I might entertain the thought of keeping two starters going -- a wet one and a dryer one. The wet one seems to have a really pronounced sour taste, and the dryer one always seemed a bit more, ummmm... refined.
                        Hi Brian!
                        You may have a relatively energetic, vigorous yeast. Mine is slightly slow. I keep it at 100% but it doesn't "crash" like yours.It is very graceful, just a little slow.
                        Look forward to your reports.
                        Jay
                          The dough rose in the bannetons last night and looked great this morning. I'm baking in the kitchen oven... it's heating up now. Dough smells great. Will report back later today, probably after dinner!
                            Waiting for the pics ...
                            / Rossco
                              I'll try, but I'm somewhat handicapped: no digital camera. I still shoot film... and generally large format film. If the second loaf lasts until my wife comes home (she has a digicam) I can provide pics. Otherwise you might have to settle for my description: not quite as much oven-spring as I would like, but nice texture and a pronounced sourdough flavor. All in all I'm very happy about the bread, and about the lesson in transitioning from a wet starter to firm starter before building the dough.
