Instant-read probe thermometer - Forno Bravo Forum: The Wood-Fired Oven Community
Community Cookbook Recipe Contest
Do you have a wood fired recipe that gets rave reviews from family and friends? Now is your opportunity to not only share it with other wood fired chefs and enthusiasts, but get rewarded, too! Starting June 1 through July 30, 2016 we are holding a Summer Wood Fired Recipe Contest and the winner will receive a $75.00 shopping spree in the Forno Bravo Store.
Submit your recipes through the Forno Bravo Community Cookbook “Submit a Recipe” button. The winner will be based on the number of votes the recipe receives. A link to the recipes will be posted on the Forno Bravo Facebook, Google+, Instagram, Twitter, Pinterest pages and the Forum. To be eligible to win, your recipe must include a photo of the dish being cooked in your wood fired oven.
See more
See less
  • Instant-read probe thermometer
    I've never baked before, and have been reading a bread baking book, trying to learn, before I start baking in my WFO. One of the tools I need is an Instant-read probe thermometer.
    Here comes the rookie question...I have a meat thermometer, and am not sure if it is the same thing. Is there a thermometer that is specific to dough?
    "Pizza, the world's most perfect food."
    Re: Instant-read probe thermometer
    It's not specific to bread, but a thermopen is the way to go. I have had one for a couple years and have nothing but great things to say about it..they are a bit pricey, but they are worth it.
      The meat thermometer will work in a pinch but the problem is that it is not INSTANT READ. The time it takes to get the temp on the standard meat thermometer is time wasted if the bread is not at correct temp. This time will slow cooking process enough to sometimes lessen the quality of a great bread.
      like chicken...
      My 44" oven in progress...
      __________________________
        I picked up two of them at Target...think they were about $12 each. Seem to work great - I tested them against each other...both had the same readings.
        RT
          Another vote for the thermapen. Much faster than the $12 unit...but the $12 is much much better than not using a thermometer...
          Thermapen Digital Thermometer
          Drake
          My Oven Thread:
            You watch out with those things, they can be dangerous! Read in the paper that some guy recently stabbed someone in the back with a meat thermometer...
            I just knock my bread on the bottom to check that its done.
              $100 for a cooking thermometer? No thanks. That is more than I paid for my IR.....and it goes to 1100 degrees, accross the room, heck - down the block (not with great accuracy at that distance).
              my $12 pen style also gives a reading in just a few seconds, and is not another expensive toy (I have plenty) I have to worry about dropping, losing...and can be replaced in 10 minutes for $12.
              To each his own, I guess...I just don't need or use one enough to justify the cost.
              RT
                Geez, Frances... What the heck is going on in Switzerland? ...Stabbing people with thermometers. I've taken guns, butcher knives, ball bats and even a homemade bomb from people. Not one thermometer.
                  I know $100 is a lot for a thermometer, but I use it all the time. Measuring the dough temp, measuring the flour temp, water temp, roasts, bread. I used the other type for many years and they are very good, but this one is truly instant and digital. I got mine as a Christmas present, but now I am hooked. If I lost it or it broke I would buy another in a second. Same with the IR therm. Lots of folks don't use them, but once you start, you are hooked.
                  I have been baking about 20lbs of bread on average. Once I have that kind of investment (in flour and time!) on bread, I want it to come out right. The difference between a loaf at a 190 degrees internal temp and 200 degrees is significant, and I want to know when the bread is done without letting a lot of heat out of the oven.
                  My Oven Thread:
                    So Drake,
                    So just what is your process for checking? Do you pull one loaf from the oven and stab it? What about different sized loaves in the same batch, check the smallest first then proceed to the next bigger? That would seem logical. Is the oven open or closed while checking or is the process so fast that it doesn't matter?
                    Thanks,
                    Wiley
                      Wiley,
                      I generally bake loaves of the same size at the same time, but I do find that the ones closer to the walls bake faster. So if I am doing baguettes, I take the door off, pull a loaf from the middle and drag it to the entry area then flip it over and test from the bottom, then test a loaf from near the wall the same way. Then put the door back on quickly (if needed). In later baking cycles (I have done as many as 4 bakes) I may have a large sourdough and a dense rye in the same bake, and they would be done at different times, and for that matter be done at different internal temps (200-205 for the sourdough and maybe 195 for the rye) so I would take the temp of both of those loaves.
                      Again to the cost of the thermometer. Everyone has something they indulge in, for me it is cooking. I have a bunch of the big Le Creuset pots and they are way too expensive, but I don't own any expensive running shoes or a sports car...
                      Drake
                      My Oven Thread:
                        Thanks Drake,
                        Oddly enough just last evening I was reading in Peter Reinhart's "The Bread Bakers Apprentice" about the need for the internal temp of bread to reach 180 F for proper gelatinization. I think I'll spring for the better quality instant thermometer. After all it's only the price of a tankful of gas :-)
                        Wiley
                          The stabber probably thought the victim had a cold and was checking for a fever.
                          My thread:
                          My costs:
                          My pics:
                            Roflmao!!!
                            like chicken...
                              I know CJ swears by the thermopen. Used it for everything....steaks, dough, bread....pricey yes....maybe someday...fathers day?
                              So Frances, was he done or not?
