Squash-Brown Butter Puree - Forno Bravo Forum: The Wood-Fired Oven Community
Community Cookbook Recipe Contest
Do you have a wood fired recipe that gets rave reviews from family and friends? Now is your opportunity to not only share it with other wood fired chefs and enthusiasts, but get rewarded, too! Starting June 1 through July 30, 2016 we are holding a Summer Wood Fired Recipe Contest and the winner will receive a $75.00 shopping spree in the Forno Bravo Store.
Submit your recipes through the Forno Bravo Community Cookbook “Submit a Recipe” button. The winner will be based on the number of votes the recipe receives. A link to the recipes will be posted on the Forno Bravo Facebook, Google+, Instagram, Twitter, Pinterest pages and the Forum. To be eligible to win, your recipe must include a photo of the dish being cooked in your wood fired oven.
See more
See less
  • Squash-Brown Butter Puree
    From the Community Cookbook: Forno Bravo Community Cookbook - Red Kuri Squash-Brown Butter Puree
    1 medium-sized red kuri squash
    1 tsp vegetable oil
    4 sprigs fresh thyme
    2 cloves garlic, peeled
    8 oz unsalted butter
    Juice of 1 lemon
    salt and black pepper, to taste
    Cut the squash in half through the stem end. Use a sturdy spoon to scoop out the seeds and guts, just like you would do with a pumpkin. Rub the two halves with the vegetable oil. Season with salt and pepper. Place 1 clove of garlic and 2 sprigs of thyme inside each cavity. Place the squash halves open side down on a small baking sheet or skillet and slide into your wood oven to roast. Cook, turning the baking sheet occasionally, until the flesh of the squash is soft. You should be able to poke the skin of the squash and feel the flesh give way underneath. This could take anywhere from 30 minutes to an hour, depending on the temp of your oven and the thickness of your squash.
    While the squash is roasting, prepare the brown butter. Place the butter in a tall-sided saucepot over medium-high heat. Allow the butter to cook. First it will boil, which will then subside and be replaced by foam. Once the mixture begins foaming, stir frequently to prevent the milk solids from adhering to the bottom of the pot. When the foam begins to dissipate, you should be able to see the browning milk solids. Once they?ve reached a nice dark brown, remove from the heat and add the lemon juice to stop the cooking process. The mixture will boil violently for a moment, so just stand back and be careful.
    Once the roasted squash is cool enough to handle, use a spoon to scoop the flesh out of the skin. Discard the thyme and garlic from the cavity. Place the flesh in the bowl of a food processor. With the motor running, slowly add the brown butter to the squash. Use the butter to taste ? it will depend on the size of your squash and your personal weakness for delicious, delicious brown butter. Some squashes have more moisture content than others as well, so if your puree seems a bit dry feel free to add a small amount of water to improve the consistency.
    Season the puree with salt and pepper to taste, serve and be ready to have leftover mashed potatoes at your next holiday dinner, because this creamy, unctuous little devil is going to steal the show.
