Roast Whole Turkey and Turkey Noodle Soup - Forno Bravo Forum: The Wood-Fired Oven Community
  • Roast Whole Turkey and Turkey Noodle Soup
    Two for One Wood Fired Thanksgiving Dinner
    Wood Fired Roasted Whole Turkey
    and
    Turkey Noodle Soup
    No need to get up at five in the morning to prepare the turkey on Thanksgiving morning. Cook a 17-pound turkey in 90 minutes to perfection. The best part, the oven will be hot enough with retained heat afterwards to make the best turkey noodle soup you have ever had with the leftovers; and you don’t have to cook dinner the next day.
    Ingredients:
    17lbs Defrosted turkey
    Olive Oil
    sea salt
    ground pepper.
    2 lg chopped brown onion (large pieces)
    4 chopped celery stalks (large pieces)
    1 handful fresh rosemary sprigs
    6 cloves of garlic quartered
    2 cups white wine
    Fire your WFO the same way you do for pizza. I use 6 pieces of split wood to start and build a tower three levels high. two on the bottom, two in the middle (90 deg off set), and two on top (90 deg offset). Once that burns for 30 mins or so lean a piece of wood against the tower on the left and right. When that all collapses, about an hour, let it continue to die down and spread the coals evenly around the edge of the dome.
    While the oven is getting hot. Rinse the defrosted turkey well inside and out. Drain. Pat dry with paper towels. Loosely stuff turkey with half of the onion, celery, rosemary and garlic. Rub the outside of the turkey with olive oil. Sprinkle with sea salt and fresh ground black pepper. Place turkey on a roasting rack inside a roasting pan. Add two cups of white wine to the pan along with the rest of the onion, celery, rosemary and garlic. Place a roasting thermometer in the thickest part of the turkey breast. Cover pan tightly with two layers heavy duty tin foil. Crimp tightly around edges and seams, you want to keep all the steam moisture inside.
    Place roasting pan on two bricks in center of oven. Cook for 80 minutes (adjust for turkey size). Remove foil and throw a small log on the coals to renew flames for browning. Retain foil. Cook 15-25 minutes with foil off and the door cracked an inch or so, watching for browning (i rotate the pan every 5-10 mins for even browning). Use a meat thermometer to monitor the internal temperature. A wood-fired oven is a naturally moist type of cooking, so the exact cooking time is less important than in a conventional oven. Take the turkey out of the oven and place turkey on large platter. Cover with tin foil and let rest.
    Pour all the drippings into a large glass measuring bowl. Add vegetables from pan and turkey. Allow to cool and separate.
    Go eat dinner.
    Part two – Turkey Noodle Soup
    Ingredients:
    Pan drippings and vegetables from Roasted Turkey
    1 Tbls Oregano
    1 Tbls Sage
    1 Tbls Thyme
    Salt and Pepper to taste
    Turkey carcass (most of the meat removed)
    Shredded leftover turkey
    4 cups Baby Carrots
    1 pkg wide egg noodles cooked al dente.
    After dinner, take all the pan drippings and remove fat from the top (you can skim it with a ladle). Add spices. Use an electric blending wand to puree all the veggies. Pour into to a large cast iron pot with the turkey carcass. Cover with water but leave enough room for 4 cups of carrots later. Cover pot and slide into the oven and close for two hours. Remove pot and remove all the bones with a slotted spoon. Add shredded turkey, baby carrots and cover. Back in the closed oven for 1 more hour. Add cooked noodles. Ready for serving or storing. Freezes well for a later date.
    Greg Geisen
    Chula Vista, CA
    Click to see my Thread:
    http://www.fornobravo.com/forum/f8/g...iego-6169.html
    Click to see Google web album:
    http://picasaweb.google.com/gpgeisen...eat=directlink
    Re: Roast Whole Turkey and Turkey Noodle Soup
    Greg, the turkey looks great. I can't think of a better way to cook non-thanksgiving turkey. When you say "fire oven for 90 min", do you just keep the logs going so a couple logs are always burning for 90 min, or do you pretty much go to "pizza temps" (ie dome clears or almost clears) ?
    I was just looking at Elizabeth's turkey she did recently and she posted it under this thread about roasting pans in post #9:
    http://www.fornobravo.com/forum/f12/...pan-13466.html
    Also, in your recipe: I gotta give you props for making soup that you don't have to add canned or boxed meat broth to in order to make it taste great. Good for you, thanks for sharing,
    -Dino
    My Oven Costs Spreadsheet
    My Oven Thread
      Dino
      I fired the WFO pretty much the same way i do for pizza but i let the fires die down. I buy my wood split. Use 6 pieces of wood to start and build a tower three levels high. two on the bottom, two in the middle 90 deg off set, and two on top 90 deg offset.
      Once that burns for 30 mins or so I lean a piece of wood against the tower on the left and right.
      When that all collapses, about an hour, the oven is at pizza temp and i push everything to the left, add a log, and throw some pie.
      for the turkey, i just let it continue to die down and spread the coals evenly around the edge of the dome.
      I think the key to the broth was pureeing the veggies and little bits of meat with the mixing wand.
      Greg Geisen
      Chula Vista, CA
        looking for a turkey
        Greg Geisen
        Chula Vista, CA
          Greg, this has been one of the most complete post's on building an oven, since I'm a newbie on here and havn't started my oven yet, I really appreciate it. One of these days I'll have to get down there and visit with you to get some ideas from you.
          Good looking family too.
          "You can tell a dutchman,
          but you can't tell him much"
            For your Bird
            Greg Geisen
            Chula Vista, CA
              Happy Thanksgiving, hope your having a great day.
                Bump up the turkey
                Greg Geisen
                Chula Vista, CA
