The Backofen
  • #46
    Re: The Backofen
    Trellis - Depends on how long ago you set those bricks. If it were me, and the bricks had been in place less than 48 hours - I would take a cold chisel and a rubber mallet and see if you can knock off the top two chains and redo them. I had a much less severe problem with the angles on my oven, and ended up doing this for one chain and I am very happy I did.
    However, IIRC - you are using HS50 - which in my experience sets up quite a bit faster - so you might not even have that much time.
    If the mortar is too set up, then removing the bricks is tricky. If you are following Texman's thread, you'll see what can happen. He ended up having to start over when he cracked his oven.
    • #47
      Re: The Backofen
      Originally posted by Coloradoredusa View Post
      5th course almost done.. pics attached!
      I can see in the pics in this post that you were started getting too shallow on your dome angle on the 4th and 5th chains. The interior face of the brick should have been flush against the bracket on your IT to get the height you were targeting.
      • #48
        Re: The Backofen
        Thanks Tscar.. I am sure it will be functional.. will just have to figure out the properties of the oven .. not gonna stress about it anymore .. @Deejay.. I can see that now too.. will make the best of it!
        “Never regret. If it's good, it's wonderful. If it's bad, it's experience.”
        Trellis
        Home Sweet Home~ Colorado Springs ~
        sigpic
        • #49
          Re: The Backofen
          Cut the next course with the top of the brick slanted to the inside of the oven at a pretty steep angle - probably need to make it 45 degrees or so. Then you'll be back on track.
          • #50
            Re: The Backofen
            DEEJAY..! Thanks! Back on track!
            Pics tomorrow!
            Trellis
            sigpic
            • #51
              Re: The Backofen
              Got back on track with the radical angle course.. halfway around the next to the last course..one brick at at a time..Stupid windy here today.. will hopefully finish this course tomorrow!
              Trellis
              sigpic
              • #52
                Re: The Backofen
                Trellis:
                Looking good...and you are so far ahead of my build, for having started more or less at the same time. Keep up the good work.Really looking forward to seeing the final product!
                RJD
                • #53
                  Re: The Backofen
                  almost to the top.. get a little more done today hopefully!
                  Trellis
                  sigpic
                  • #54
                    Re: The Backofen
                    Looking good Trellis! Nice recovery
                    I'm closing in my dome this morning. Looks like you might get there too
                    • #55
                      Re: The Backofen
                      O Yeah!.. Domed out... It's not the prettiest ,but it is nice! woohoo..!
                      Trellis
                      sigpic
                      • #56
                        Re: The Backofen
                        Well its been a while since i've posted..I managed to do the curing fires before I went on vacation..and before Colorado Springs started on fire.. I ended up with some small mortar cracks, but nothing that is structural.. pizzas were damn good and now I will concentrate on finishing the oven! I wont be able to make any Pizzas or even use the oven until the city lifts the Burn BAN on outside fires.. even ones enclosed in Fireboxes..aka fire pits aka BBQ pits Dangit...
                        Trellis
                        sigpic
                        • #57
                          Re: The Backofen
                          Yep, we have that ban in Douglas county too!!
                          My Oven Thread:
                          • #58
                            Re: The Backofen
                            Vermicrete insulation layer ..complete..! Fired yesterday afternoon and oven is still at 400 deg as of noon MST! Steel door fit into place!
                            Trellis
                            sigpic
                            • #59
                              Re: The Backofen
                              Glad you are OK Trellis. Your oven is looking good!
                              The fire got within 150 yards of our old house on Granby Circle. Friends, neighbors and my brother had to evacuate....Some came back to ashes. One friend, who lived through WWII in Germany thought it was the end of the world. Her grandson helped her out to the car and the flames, smoke and embers were unbelievable....She made it with three suitcases....
                              Lee B.
                              DFW area, Texas, USA
                              • #60
                                Re: The Backofen
                                Hey, Trellis:
                                Saw your message regarding my build. Thanks for the encouragement.
                                Congrats on your own success---you rocked getting that oven built! And the first pizza looks great. I hope that the continued threat from the fires out there hasn't prevented you from continuing to enjoy the fruits of your labor.
                                By the way, are you planning to brick in your chimney? I'm undecided still about how I will finish the enclosing structure after the oven is built, and always looking for ideas.
                                Robert
