Chimney - Forno Bravo Forum: The Wood-Fired Oven Community
Chimney
  • Chimney
    Ive just knocked down my pizza oven and im going to build a Pompeii style oven in its place , but I would like to keep the stack sat in the middle of the dome ....this presents me with a problem ....heatloss!
    has anyone come across this problem .... and found a solution ?
    my solution would probably be to build a 36" firebrick dome and using precast pumice or similar flue liners form an "elephants Trunk" from the front entrance back up the inner dome to the center where I can spring the stack up off.
    Then put the outer skin of brick to cover
    Have I just answered my own thread ?
    Re: Chimney
    G'day
    Known as a squirrel tail, good you thought of insulating the chimney as well otherwise they can be prone to heat loss as well.
    Why are you pulling down your old oven?
    It's quite a good looking structure, like the chimney that's a piece of work why pull it down?
      Re: Chimney
      Pulled it down now......a tree hit the stack during some high winds knocking the pot and a course of brick off and fractured the base so it was rocking (just the stack) so it was unsafe, any cheers for the thumbs up on the old 1
        Re: Chimney
          Re: Chimney
          You shouldn't lose any heat if you insulate the dome and place the throat outside the oven opening.
          Old World Stone & Garden
          John Ruskin
            Re: Chimney
            Love the chimney
