Ularu finished - Forno Bravo Forum: The Wood-Fired Oven Community
Ularu finished
  • Ularu finished
    Well I put the final render onto the oven today. The wife wanted "Tuscany - like a terracotta" no problem I think...
    The cement oxide color said Tuscany, it looked like terracotta. But when mixed with the grey cement it came our much darker.
    Oh well, we have named it Ularu, for those non-Australian's you may need to google Ularu to understand why
    OK - let it dry tomorrow and pizza on Monday, its a public holiday here. Quite appropriately Labor Day, man have I labored!
    Re: Ularu finished
    Hi, Talisker!
    If your wife ain't happy, you could always try Dulux Tuscan Effects in the terracotta shade... show her Forno del Gallo in my picasaweb album for the effect :-)
    BTW, I hope you named it Uluru rpt Uluru, or those ancient ones will be offended...
    Cheers,
    LMH
      Re: Ularu finished
      You mean this:
      A fine name indeed. Is it volcanic? that would be even more appropriate.
        Re: Ularu finished
        Well, I googled "Ularu" and got many hits, should have checked better. I'll most likely get a bone pointed at me now.
        Comments from friends are I should continue the decoration with concrete kangaroo's and a statue of Neville. Maybe a dot painting on the side?
          Re: Ularu finished
          Try Uluru Great looking oven.
            Re: Ularu finished
            I like the colour! Nice and earthy.
            Any why NOT decorate it with kangaroos and a dot painting?! It'd be cool!
              Re: Ularu finished
              ...spare me please!...it's Ayres Rock!
                Re: Ularu finished
                only for less than 200 years
                  Re: Ularu finished
                  ...might as well start calling Australia "New Holland" then, based on that theory!
                    Re: Ularu finished
                    When colouring the cement with oxide the greyness of the cement always tends to dull the colour. This can be overcome using white cement. You need tons of the oxide coloring to colour the complete mixture and it ends up being quite expensive. I think a better solution is to make a thin top coat using white cement coloured with a proportionately smaller amount of oxide. Or simply use an exterior acrylic paint. Because the outside of the oven gets dirty, if you want it looking new all the time, then it needs a spuce up annually anyway.
                      Re: Ularu finished
                      Pretty sure that would be just giving it another white man's name perpetuating the Terra nullius mythology,but wouldn't in any way be helpful in resolving the lack of acceptance for the colour of the skin of his oven.
