Sean's Oven - Forno Bravo Forum: The Wood-Fired Oven Community
Sean's Oven
  • Sean's Oven
    Hey everyone,
    I started my oven last weekend; we have the slab poured and the first course of brick down. This weekend we are planning to lay the rest of the block for the walls and pour the hearth.
    A thing to note...
    When we poured the slab we leveled it but did not completely finish it. We made the mistake of returning the mixer and it took longer than expected. By the time we returned the concrete was already too hard to smooth out. It?s ok since no one will see it. I will say we were attempting a rustic look .
    More pictures to follow.
    -Sean
    Re: Sean's Oven
    One question, for the hearth should I use Vermiculite or FB board? If I go with FB board how does it stick to the hearth?
    -Sean
      Re: Sean's Oven
      Hi, Sean.
      The vermiculite concrete should be four inches thick for proper insulation. Cal-sil (FB) board will work at a two inch thickness. I used a mineral wool product from HW, insblock19, which came in 2.5 inch thickness. I laid the board down directly into the wet concrete of the support slab, and it worked well. The Cal-sil board has a tendency to soak up water, and will suck the moisture out of your concrete if you apply it directly. It has been suggested to place vapor barrier plastic over the wet concrete, and put your boards down, that way you can thump them into position, and get a good match between the surfaces, but the board won't effect the concrete.
      There is also a refractory adhesive sold in tubes for caulking guns, but I don't think many people here have used it. It's expensive.
        Re: Sean's Oven
        From what I've heard (being a vemiculite hearth insulator), the FB insulating board sticks to the hearth by gravity. Put it down, build an 800 kg oven on top... it won't go anywhere...
          Re: Sean's Oven
          agree 100
          I just put my FB board down - no adhesive. Trust me - it's not going anywhere.
          Dick
            Re: Sean's Oven
            Great to see another oven started. Where are you in CA?
            My Oven Thread:
              Re: Sean's Oven
              Sean
              From your pix looks like you're building an extension to the right...will that be prep surface? or grill?
              Craig
              "If you think you can do a thing or think you can't do a thing, you're right." - Henry Ford
                Re: Sean's Oven
                Dmun, Frances and TheBadger:
                Thanks for the reply, it sounds like FB board is the recommended way to go? If I go with FB board should I pour a 3.5" hearth still or go a bit thicker?
                Also another question what mortar should I use for the oven?
                Drake,
                I'm in Walnut Creek CA
                Cplain,
                I am planning on it being a prep surface.
                Thanks all for the responses; I am hoping to be curing the oven in a few weeks!
                -Sean
                  Re: Sean's Oven
                  For the mortar, I would go with Refmix. The stuff is easy to work with, and is rock solid.
                  "Pizza, the world's most perfect food."
                    Re: Sean's Oven
                    Originally posted by dmun View Post
                    <snip>
                    Hi dmun, do you happen to know name/brand of such adhesive? I need exactly that to 'glue' together two halves of my oven door ( the one that doesn't have any touching metal parts but is held together by the insulation)...
                    Cheers,
                    LMH
                      Re: Sean's Oven
                      This is the stuff I mean:
                      Refractory Mortar, Sealant 3200 degree 11 oz. tube - eBay (item 3852622609 end time Jun-24-08 08:03:04 PDT)
                      You could ask the vendor if the product is right for your application.
                        Re: Sean's Oven
                        <snip>
                        Thanks mate! Looks like it's more intended as a sealant than a 'glue' but will check it out...
                        Rgds,
                        LMH
                          Re: Sean's Oven
                          PROGRESS!
                          So, OK I am not a good concrete guy, that’s ok it will be covered! I did build my slab a bit thick and mixed the vermiculite separate which was poured a few days later. Since I had to burn the entire yard of concrete I didn’t leave 4 inches for vermiculite. I will pour a 3 inch layer on top of the existing slab like I have seen others do. This will give me about 5 inches of vermiculite, which should keep it nice and warm.
                          -Sean
                            Re: Sean's Oven
                            What goes on the offshoot to the right? Is it just counter with storage underneath?
                            Your concrete looks great, not to worry. As you said, it gets covered.
                            Elizabeth
                              Re: Sean's Oven
                              Did you decide to used vermiculite instead of the FB board, or together?
                              Mike - Saginaw, MI
                              Picasa Web Album
                              My oven build thread
