Todd's Oven
  • #16
    Re: Todd's Oven
    Ya I was thinking this is the way some adult films start...
    dow chika dow dow
    I got off with a warning for not having my front plate mounted on my car...
    • #17
      Re: Todd's Oven
      What is the maximum temperature you will see in a pizza oven?
      • #18
        Re: Todd's Oven
        How much wood do you have? I pegged my meter at 968 degress, I'm sure it got hotter than that.
        Les...
        • #19
          Re: Todd's Oven
          The reason im asking is I use regular 120v 71w UV lenes MR16 Halogen bulbs in my powder-coat oven and run it up to 1000f on a regular basis and they seem to survive quite happily at that temp. I wonder if they would survive recessed into a dome brick???
          • #20
            Re: Todd's Oven
            Spent most of the day making tools to cut bricks...
            but I did get the first two rows cut..
            here they are just dry stacked.
            Wonder if I can do it without heatstop...Hmmm...
            • #21
              Re: Todd's Oven
              Todd,
              On the first couple rows of the fire brick the angle on the bricks where they meet doesn't demand much heat stop to get the brick to come together. This changes as you work up the dome.
              Unless you are willing to make the time to cut 30 to 40 % (maybe more?) out of each brick to create the custom shape, the brick work at the middle and top of the curve on your oven will go together much faster with the mortar. As you get closer to to the top of the oven the angles on the adjoining sides, top and bottom faces of the brick get steep. It is pretty easy to fill those spaces with mortar, and time and brick consuming to fit each brick to the space.
              Some of the guys do pay close attention to the detail and create beautiful ovens with carefully crafted brick - fantastic workmanship. Many of us use lots of heat stop. Both ovens make great pizza.
              Your choice.
              JED
              • #22
                Re: Todd's Oven
                Thanks JED,
                I am going to use minimal heat stop to glue it all together but it may be therapeutic to my OCD to fit cut all the bricks. Il see how far I get..
                • #23
                  Re: Todd's Oven
                  Got a little more done.. all just dry stack as I am waiting for the heatstop 50.
                  • #24
                    Re: Todd's Oven
                    • #25
                      Re: Todd's Oven
                      Todd,
                      Who needs mortar? Your cuts and bricks are so tight, this thing is going to rival Les' dome. Lookin' good!!
                      Ken H. - Kentucky
                      42" Pompeii
                      • #26
                        Re: Todd's Oven
                        Wow, this is going to be a seriously cool oven. Nice brickwork so far!
                        What's the whitish-looking brick in the middle of the oven floor? Just curious.
                        Not to insult your intelligence, but don't impale yourself on that rebar! Might want to put caps or tennis balls on those things, especially when you start walking on the hearth to reach the upper dome.
                        Picasa web album
                        Oven-building thread
                        • #27
                          Re: Todd's Oven
                          Thanks Ken... im still on the easy part... learning a lot by trial and error...
                          Funny to think i came here thinking i was going to be building a fat barrel oven to cook fast pizza
                          • #28
                            Re: Todd's Oven
                            Thanks dbhansen,
                            GOOD POINT about the rebar! I have not been up there yet but I will be soon.
                            The white brick was just a dry brick that I sat in after I had wetted down the others. Its the one where my thermocouple goes.
                            • #29
                              Re: Todd's Oven
                              Moving at normal speed and taking mandatory beverage breaks I find that I am able to mark and cut about ten bricks per hour.
                              • #30
                                Re: Todd's Oven
                                Hmmm... sounds like sage advice from "Daren the Impaler" (or is it "Daren the Impaled")
                                Ken H. - Kentucky
                                42" Pompeii
