Forno Montagna - Forno Bravo Forum: The Wood-Fired Oven Community
Forno Montagna
  • Forno Montagna
    This is the start to my oven build thread.
    Re: Forno Montagna
    In the beginning... We have a large hill in our back yard and have been developing the gardens for years. 2 years ago we built a retaining wall to create a level area to relax, have camp fires, etc...
      Re: Forno Montagna
      Last year (2008) I discovered this site and had the idea about adding an oven as the focal point of this space. After roughing in the foundation and back retaining wall we hit a large vein of sandstone! That halted the project and wore out some shovels and backs.
      This spring, we rented a jack hammer and the project took off! 5 weeks later we have completed the foundation slab, block foundation, framed and poured the hearth, built the back retaining wall and now working on the pergola. Perhaps it is premature to built that next before the dome, but I wanted to use it as a support for a tarp to cover the work site as I build the dome.
        Re: Forno Montagna
        The hearth frame and pour went very well. My wife, two sons and father made it a great day. It is now a family obsession.
          Re: Forno Montagna
          A friend has declared it "forno montagna" fire mountain. Great name.
            Re: Forno Montagna
            We dug a few holes for the pergola posts and placed a few extra pieces in to evaluate the scale. We like it! My wife added rocks and mulch around the back side, nice touch. Will try to build the pergola this weekend, then a summer vacation and on to the dome!
              Re: Forno Montagna
              site plans for forno montanga
                Re: Forno Montagna
                What an excellent yard you have! You have made a great start, thanks for the pictures!
                Drake
                My Oven Thread:
                  Re: Forno Montagna
                  Thanks Drake!
                    Re: Forno Montagna
                    The Forno Montagna project looks fantastic. I look forward to to following you progress.
                    Cheers,
                    John
                      Re: Forno Montagna
                      Cheers,
                      John
                      +1... ...Absolutely fantastic!
                      To the OP:
                      I have a similarly sloping back yard which is in planning stages of terracing one section and I can't decide what material to use as retaining wall. I was thinking either railroad ties or cement landscaping blocks.
                      What type of timber did you use? The finish is very clean.
                      Thank you!
                      George
                      My 34" WFO build
                        Re: Forno Montagna
                        Thank you!
                        6x6 green-treated landscape timbers, inexpensive and very easy to work with.
                          Re: Forno Montagna
                          Forno Friends, I am preparing for the dome phase. Can anyone help with info on how to determine quantity of bricks I need? I plan on a 36 inch interior. Also, how many insulation boards? I think I need 4 sheets at 24x36?
                            Re: Forno Montagna
                            You could do worse than using the pompeii kit specs as your guideline: (PDF)
                            http://www.fornobravo.com/forum/atta..._datasheet.pdf
                              Re: Forno Montagna
                              Hi Dan,
                              1st of all, GREAT LOOKING OVEN BASE! The setting is nice and you've built the base with lots of steel and cement. It's going to be strong. I like you pic of the pergola and oven. It'll look great.
                              Hopefully I'm not too late re: your question about 24x36 insulation board. I've built a 42" WFO and I purchased 3 of boards and I had to be really clever to make every bit work and have a few 2" useless pieces left over. Your oven is a little smaller so I would think you still need 3 (not 4). If you already bought 4, then the extra would be great to use inside an oven door.
                              Looking foreword to watching the rest your build. Let us know if you have any questions. You and your family look like your having fun and the best parts are just starting!
                              Happy oven building, Dino
                              My Oven Costs Spreadsheet
                              My Oven Thread
