36" Tall Man's Oven Build
  • #46
    Re: 36" Tall Man's Oven Build
    Hi Mark,
    No, what I'm saying is that some of the influences of optimal draft through the chimney are simply out of our control. Because the inlet and outlet of the chimney are both subjected to wind influence, the pressure differentials between the two ends of the conduit can influence the effectivness of the draw through the chimney. This draw through the chimney is soley relient on the bouyancy of the the constituant gasses.
    Just as an automotive engine needs fuel, compression, and spark/timing, combustion of wood requires "the three T's"; Time, Temperature, and Turbulence. Temperature is non-issue in a WFO. Time means time for the fuel and oxidizer molecules to mingle and find one-another. Turbulence is the the flow medium that allows the fuel and oxidizer to fold-together and mix into a combustible mixture. In our WFO's, the basic design is so that the flue gasses (which are high in temperature and more bouyant) rise upward and force there way out of the top of the door opening. This exidous is supplanted with incoming air which comes in low and spreads across the floor to feed the fire. This is all well and good, and works very well as a usable system.
    However, at extremely high temperatures, the wood in a WFO will at times volatize at a rate wich is much greater than the static system design can optimize a mixing (time and turbulence) for the air and fuel constituants. Wood is a hydro-carbon fuel and hydrogen oxidizes much more easily than carbon. So, when conditions do not promote complete combustion, the hydrogen will play along, but not all of the carbon. The result is soot.
    In short, all I am saying is that WFO's are what they are and that the major attributes that influences the spillage of an outdoor WFO is an ample throat area to the chimney and the effects of wind.
    I think all WFO's will spill to some degree. It's OK. We just made sure our chimnry was high enough to keep any dense discharges of smoke from people's faces when burning the oven hard. Also, we're just talking about when the oven is at "high-fire".
    Ken Morgan
    • #47
      Hey Ken, your profile says you're a wood fire safety testing supervisor. Man you've got a lot of good knowledge in this area! When I was reading your reply I wondered: What's this guy do for work? Then I looked at your profile and voila! Makes sense why you're "up" on this stuff.
      You are suggesting that there is a point where my chimney flue is too high. We have a wood stove we heat our house with and it has great draw and we never have a problem with smoke in the house, even when I have the damper almost completely choked and I'm loading wood. Since this length of chimney is working well in the house, I'll use it as a gauge and make sure my wfo chimney isn't much taller. I hope that sounds reasonable.
      Darius
      • #48
        Sounds very reasonable Darius. I was just trying to point-out that tall enough is "tall enough". Of course, local building codes will dictate chimney height requirements when within X feet of the house or other structures... Your household fireplace/wood stove is not subject to winds at the inlet of the chimney, and the chimney is probabaly insulated very well. A wood stove is a sealed appliance and does not scarf-up a large quantity of excess air either. Also, if your stove is younger than 20 years, it has emission-control designed into it. I don't think you can equate an indoor stove with an outdoor oven in regards to chimney performance. I think if you run it hard and it smokes hard, with a definatley black smoke, then you are over-firing it. By over-firing, I mean that the rapid burn-rate is being discounted by less than optimal combustion efficiency. If you backed-off on the amount of fuel, even though the burn-rate is lower, the effective energy release could be just as good if the combustion efficiency is improved.
        I guess all I'm saying is that these oven designs are elegantly simple and work very well. Each oven will have it's own attributes and the user just needs to get to know the personality of his/her unique oven. Over-firing and creating mass quantities of soot is a sure sign of waste. As for chimney height, if it draws fairly well when hot and carries the smoke away...all is good.
        Ken
        • #49
          Well I'm going to be very gentle with my baby, so I won't be building any raging inferno's. Maybe after testing for a while I'll crank up the heat, but if smoke starts pouring out the oven you're saying I've over-fueled it. I think I got it.
          • #50
            Black smoke - you'll know the difference, but yeah- you got it!
            • #51
              Holy crap ken, Quite an explanation.... But a really good one that makes sense... THanks.. Since you know a bit about this I want to ask you an off topic question,,
              Do you think Wood Gasification is a viable alternative ?? Are you familiar with it ?
              No need to elaborate,,, (unless you want to)
              Mark
              • #52
                Hey Mark - I don't want to diverge on Darius's thread, but no. It works, but is not very efficient. It is very interesting though. Do a google on "Holzgaz" or "Holtzgas". They put this concept to work in Germany late in the war during their moment of desperation.
                Darius- How's the dome doing? Did you squeeze in there and finish filling all the little pockets in the last few courses? It's sort of fun to tend the early curing fires while you continue working around the oven.
                Ken Morgan
                • #53
                  hey ken,,
                  Thanks,, darius,, sorry for interupting...
                  Mark
                  • #54
                    Yo Mark! No apology necessary! Thats what this forum is all about- learning from one another. This is all our thread!
                    No Ken, I have yet to set a flame inside the dome. I was thinking I'd let it really dry out for a while, maybe a week or two. I read a thread(don't remember what section of the forum or the name of the thread) on making sure there was no moisture left in the mortar. That this is the most likely culprit of the accursed cracks. I was thinking of putting a heating element inside it and bringing up the temperature until the outside reaches in the inside dome temperature, like I read in that same thread.
                    Truthfully, I am at a snag in my progress- I need to get my hands on some more cash before I can continue the project. I want to build my wood frame for the roof, get the chimney materials, and the FB blankets for the 3" of insulation for the dome. Surviving mostly off of unemployment doesn't leave a whole lot of cash left over for oven building. I need to rustle up some work to gather up the stuff for my next project phase so it may be a couple weeks or so before I can post any progress.
                    Darius
                    • #55
                      Darius,
                      If you have a small electric heater you can throw that in there for a while to help dry it out..
                      • #56
                        I do have one. Thanks for the tip Mark!
                        Darius
                        • #57
                          Darius,
                          Here is the post you mentioned. I have it book-marked because I plan on following the same curing schedule. It makes sense to me...
                          http://www.fornobravo.com/forum/8/co...en-7630-2.html
                          Good luck with the rest of the build!
                          Regards,
                          Bob
                          My Oven Progress: http://www.fornobravo.com/forum/f8/p...uild-7155.html
                          If you fail to plan, you plan to fail!
                          • #58
                            Thanks for the link Bob. How's your build coming along?
                            • #59
                              Darius,
                              Slow, slow, slow! I really wanted to get this done before the snow but it's not looking good. I just haven't had time to get out there.
                              I completed course #5. The picture below shows course #4 completed...
                              ~Bob
                              • #60
                                Hang tough man, it's coming along! The only reason I was able to put the crunch on mine it because I've been laid off work. I wish I was busy working and oven building in the evenings/weekends instead of this just barley getting by crap. Of course the positive side of this is I get to spend more time on my oven build. I'll keep an eye out for additional progress on your building thread.
                                Keep up the good work (on the oven and in the real world)!
                                Darius
