help in southern ma. - Forno Bravo Forum: The Wood-Fired Oven Community
  • help in southern ma.
    I'm about to place the blanket on my stove i have cooked in it twice already and it had 2 small cracks that i took care of .. my question is when i put on the blanket do i just use regular stucco right over the blanket and will this protect it when it snows ? id like to use oven year round...thanx in advance
    Re: help in southern ma.
    Many people have had success with stucco coverings: I remain sceptical. Look around your neighborhood. Do buildings that need to stay dry have stucco roofs?
    If you go the exposed dome route, think carefully about the various ways the water can get in. This includes the flue area, the opening around the door, the joint between the base and the dome.
    Remember: wet insulation is pretty much no insulation.
      You would need to cover blanket with something first! i used vermicrete. about 3 inches. then i tried stucco and it didn't hold up. i am in southern MA also. I think if you were real experienced with stucco you could make it work. I was not and it didn't. Here is a picture of mine
        so dmun what do you recommend i put on over the blanket ?
          The render is way too thin, thats why it didnt work on top of the crumbly vermicrete.
          You would need about 25mm at least I would have thought.
            Nearly all the house on Santorini have concrete domed roofs.
