Burning Cheese - Forno Bravo Forum: The Wood-Fired Oven Community
Burning Cheese
  • Burning Cheese
    for some reason my mozzarella cheese has started burning. i have not changed the temperature, location of the pizza, or the brand of the cheese. what could be causing this?
    Re: Burning Cheese
    Heat will burn cheese, wood or the earth itself, if it get hot enough! To help you with your problem we need a little more details.
      Re: Burning Cheese
      thank you for the info. we have been making pizzas with the same cheese and the same heat for over a month now. but all of sudden, with no changes made to the head or the cheese, the cheese started burning.
        Re: Burning Cheese
        Maybe the cheese changed its formula and started using powdered milk
          Re: Burning Cheese
          How is it burning in relation to how the pizza is baking? Does the cheese burn while the crust is doughy, is the other topping cooked or un-cooked. Will moving the pizza back from the fire help, is all of the cheese burning or in spots???????
            Re: Burning Cheese
            Are you using part skim cheese?
            Old World Stone & Garden
            John Ruskin
              Re: Burning Cheese
              Did you change the way you slice/shred it?
                Re: Burning Cheese
                Maybe your oven dried out and is hotter???
