daves build - Forno Bravo Forum: The Wood-Fired Oven Community
daves build
  • daves build
    Gday all,
    I have just poured 2nd slab and while I am waiting for that to cure I was going to brick up the stand.Having never done this before, should I use a string line? or just go off the blocks? any tips or suggestions would be most welcome
    Re: daves build
    Dave,
    now you've got me confused!
    From the picture provided, it looks like you have already done the stand, now you need to put in your insulation layer(s) and then either your heart (if you are going to sit your dome on that) or your soldier course and then put your hearth in it before you close your dome.
    What stand were you referring to?
    Cheers.
    Neillís Pompeiii #1
    Neillís kitchen underway
      Re: daves build
      You want to lay up face bricks on the exterior of the stand? There's no reason why you can't just use the stand as your guide. It looks like your stand protrudes enough for the brick facing to have a good footing.
      If you haven't laid brick before, you may want to look into the bricky tool. I used it, and I recommend it. It makes bad bricklayers good, and good ones fast.
        Re: daves build
        thx dmun ,
        I thought that I could use the stand wall as a guide, its not perfectly str8 but it will do the job I think. I appreciate the feedback.
        Dave
          Re: daves build
          sry nissan I meant I am going to put normal reds around the stand before starting on the dome. I was just going to let the 2nd slab really set before loading it up as I would be fairly put out if it cracked(not that it would) because I was impatient.
          cheers
            Re: daves build
            Use a plumbob or level to bring down each upper corner to the foundation. mark that point as the inner face of your brick veneer. If the stand is out of plumb, this will ensure that the veneer will meet the top of the base and can be built plumb while doing so.
            To lay it, use your level vertically, horizontally and across the face to build the corners out, then use a string between the corners to lay the filler brick.
              Re: daves build
              thx tscar
              I will certainly do that, all good info, thankyou.
                Re: daves build
                thanks guys for your help I seem to be struggling through it, this is the first time I have ever laid any bricks! managed to get a few courses done today, even getting into the lingo! its not perfect but I am moving forward, which is the main thing.
                  Re: daves build
                  Ok I just saw it myself yes that corner brick is upside down! getting a bit weary by the end of the day, 3 kids , wife just had knee reconstruction!
                  cheers
                  dave
                    Re: daves build
                    update, got another course of bricks done. and started on dome
                      Re: daves build
                      I was wondering regarding the refractory mortar how long it takes to dry? or does it always remain slightly pliable? seems to have properties like a hard putty!
                      cheers
                      dave
                        Re: daves build
                        No - it should dry rock hard and fairly fast. What did you use?
                          Re: daves build
                          Which refractory mortar? If you mean homebrew, it takes a very long time to thoroughly harden, like weeks (and it probably isn't truly finished until you cure the oven with fire). If you mean the premixed, like HeatStop, then I have no experience with it.
                          I was impressed over the course of my build how the old mortar slowly got harder and harder. But honestly, it took weeks.
                          The slower is cures, the stronger it'll be...I think.
                            Re: daves build
                            I used the bag stuff and just added water to a peanutbutter consistency!
                            I also put the fire bricks in water before laying so they didnt suck water out of mortar, that was last night and this morning you can still push your finger into it! can I lay anoter ring ontop of that? its hard but not like real mortar
                              Re: daves build
                              Hey les, love your build, awesome!
                              I might have to speak to you later on about how you tie the barby into that benchtop!
