Vermiculite Info - Forno Bravo Forum: The Wood-Fired Oven Community
Vermiculite Info
  • Vermiculite Info
    Is the vermiculite I would use as an insulator, the same stuff you can buy in the lawn and garden deptartment or is it something else. Where can I get it at? Thanks
    Vermiculite
    Welcome aboard,
    That's it. You can find vermiculite at some Home Depot stores, and at wholesale garden supply stores, in 4 cu. ft. bags. Don't buy it in small bags, or it will add up.
    Here are a couple of useful links:
    http://fornobravo.com/forum/showthread.php?t=361
    http://fornobravo.com/forum/showthread.php?t=659
    For Under Oven insulation, you might want to consider Super Isol, a rigid insulating board.
    http://fornobravo.com/store/product....cat=248&page=1
      I found my vermiculite and perlite at a hydroponics supply store. I just finished the insulating hearth today. It took just over four bags ($100) of perlite and about three hours (including start up and clean up) to cover the entire hearth.
      In hindsight, the SuperIsol would have been a better use of my time, but I'm having fun trying to do my first oven as cheaply as possible (but no cheaper).
      -Chris
      -Chris-
      I'm building a Pompeii Oven in Austin, Texas. See my progress at:
      Il Forno Fumoso
        I was horified by the first little batch of pearlite concrete I mixed up to go under my fireplace floor. What is this mess, I thought, but it hardened up to a really solid surface. The edges of it don't have any kind of hardness, but they don't fall apart, and it will all be covered up in my plan anyway.
          If Perlite is used, then be sure it is agricultural grade!
          (M) If you decide instead to use Perlite rather than Vermiculite, be sure that the Perlite is agricultural grade. The construction grade is coated with silicon and is *not* what you want. In mixing Perlite as an aggragate, it needs to be able to absorb water!
          Ciao,
          Marcel
