Insulation Q for those who built with cement cladding - Forno Bravo Forum: The Wood-Fired Oven Community
  • Insulation Q for those who built with cement cladding
    Hi All,
    This is a question for those who have built (or who are building and have read about) an oven with cement cladding (i.e. allen scott and /or rado hand designed oven)
    I'm wondering if you also put down fire blankets between cement cladding dome and the loose vermiculite/perlite layer.
    __________________________
    LOOSE VERMICULITE
    FIRE BLANKET
    CEMENT CLADDING
    For those who just put vemiculite ontop of the cement cladding,, how does the oven perform and would you recommend adding a layer of fire blanket?
    LOOSE VERMICULITE
    CEMENT CLADDING
    I'm running low on funds and trying to decide if i need the fire blanket or not .....
    Any comments / suggestion appreciated.
    Thanks in advance
    Gi
    Re: Insulation Q for those who built with cement cladding
    you can do it without the fire blanket, i did...but you can probably find that at some appliance junkyard for cheap.
