A newbie’s survey of the Forno Bravo treasures hiding in the archives
This is a sticky topic.
  • #76
    Re: A newbie?s survey of the Forno Bravo treasures hiding in the archives
    my turn to bump.
    • #77
      Bump
      You turn next month Russell
      • #78
        Keeping this thread up front to help all the builders.
        • #79
          I feel Les oven build should be listed here also, i thought it was in this list, but alas, it is not. Maybe the main page needs to be refreshed from time to time to catch newer techniques and builds. Just a thought !!!!!!!
          Cheers Colin
          • #80
            Love it. All the Vets backslapping and BS'ing--truly shows shows a sense on comradery on the forum. It's been a year and a month since the last post on this thread guys; sun's out! Time to start building again. Winter is over. Hopefully, some of you giants will be around to weigh in when I start posting my build. It's going to be a doozie. Until then...
            • #81
              Good luck on your wood fired oven journey Seven :highfive:
              Keep in mind that the planning stage of your build is more important than you think. Take your time.
              Lee B.
              DFW area, Texas, USA
              • #82
                Time to bump
                Cheers Colin
                • #83
                  Bumper time
                  • #84
                    October bump ... time to start thinking Turkey, Ham, & Prime Rib friend/family dinners!
                    Roseburg, Oregon
                    • #85
                      Wise words for sure. Planning takes time. Tearing down and rebuilding takes more.
                      • #86
                        Lee,
                        There is probably a better place to ask you this question... for some reason I couldn't find your build thread (only your album).
                        How hot does the granite under your vent get? I am debating on doing something similar, but not sure about surface temps.
                        Thanks,
                        John
                        • #87
                          John, If memory serves, the granite gets up to 200-230 F, no spalling yet. We can fry bacon in a cast iron pan the day after pizza with pan half on oven floor and half on the granite. I didn't make a build thread, just the albums. HTH
                          Lee B.
                          • #88
                            Lee, Another Great build was K79 or on you tube the wicked outdoors
                            • #89
                              Just an FYI on turkey oven fitting (through the entry). Got a 21.7 pound (9.8 KG) turkey on Saturday sale at Costco after Thanksgiving. Turkey on the rack, in a roaster pan is only about 9.25" (23.5 cm) high ... just an FYI, so you don't have to take a ruler into the grocery store
                              ...and also the December bump for this thread
                              Roseburg, Oregon
                              • #90
                                G'day
                                Monthly bump..... Check out the links at the front of this thread
