My oven Plans
  • #16
    Re: My oven Plans
    This is because their plans have a 6 inch "oven landing." I am assuming that this is a 6 in space to give room to build a arch, or to have some space in front.
    Or to have a vent and chimney. Cooking with combustion gasses in your face is going to get old really fast. I'd plan for a vent. Apologies if you've thought of this already, and are talking about something else.
    Is it worth it to get the bigger oven?
    Yes. In anything much under a 36 inch (900mm) you're really pressed for room. I'd get as close to this size as you can.
    • #17
      Re: My oven Plans
      Now I am ready to order the oven. Been speaking with a FB dealer to order a Giardino 70. He recommended that I look into building a wood stand for my needs. I LIKE THAT IDEA!
      Yes I know.... there will be some haters out there. But if done properly, I can't see this being a problem.
      So here are my new plans. I took some photos from another forum and put them on my plans too.
      • #18
        Re: My oven Plans
        I finnally ordered my Giardino 70 oven today! I am soooooo excited!
        • #19
          Re: My oven Plans
          My oven is coming along.
          • #20
            Re: My oven Plans
            Mighty Tidy horrocks007!
            Have you rolled it around yet to test the cart on that irregular surface?
            Can't wait to see your first pizza.
            Lee B.
            DFW area, Texas, USA
            • #21
              Re: My oven Plans
              Is that enough of a firebrake between the wood surface?
              • #22
                Re: My oven Plans
                Have you rolled it around yet to test the cart on tha irregular surface?
                I did a test roll this morning, no problems! Doesn't roll fast due to it's weight, but no hang-ups on the surface. My patio is old mossy cobble stone. I ended up using 300 pound casters.
                I am using the 2" FB Board and 1/2" Wonderboard. I am copying other members' plans with regards to keeping my oven stand from burning to the ground.
                Eventually this oven will be relocated on a more permanent home, but it could be 10 years down the road.
                Anyone know how many bags of stucco mix I will need to do the dome?
                • #23
                  Re: My oven Plans
                  More Photo's-
                  Insulation
                  Merle
                  1st coat succo.
                  Almost done!!!
                  • #24
                    Re: My oven Plans
                    Looks great, how long until you fire?
                    • #25
                      Re: My oven Plans
                      Depends on when I get the second coat of stucco (I hope tomorrow). 2 weeks after that, if not 3. I am hoping to cook pizzas for my wife's birthday on the 25th.
                      • #26
                        Re: My oven Plans
                        I'm pulling for the long term success with your oven & stand, it looks great. It has gone together pretty quickly, huh?
                        Lee B.
                        • #27
                          Re: My oven Plans
                          2 winters later, and my oven is still in great condition. I need to stain my wood on the stand, will this summer.
                          The only problem I've had is the Mexican taverna tiles I put around the boarder have been cracking apart and falling off. I tried re-glueing them with liquid nails, which seems to hold better than thin-set, but the tiles are starting to flake apart from the surface. They are glued onto cement board, but I am thinking that they are getting wet and not drying out, so they are flaking apart. I think I should have put down some water proofer like you would in a tub or a shower. I guess this summer I will re-tile the surface with something less porous, and try to use some water proofing too.
                          Maybe I should be covering the oven more too. Kinda in a pain the a** to do, as I use it nearly every other weekend.
                          • #28
                            Re: My oven Plans
                            I like the mexican tile look but winter's freeze thaw cycle are killer on them.
                            • #29
                              Re: My oven Plans
                              Great job!
                              I would suggest porcelain tiles, but you can ask a tile dealer. They sell tiles specifically for outdoors. You may not be able to use a glazed tile without spalling (flaking).
                              • #30
                                Re: My oven Plans
                                That's a great Oven and brilliant Stand from which I am tempted to go down the wood stand route.
                                I have an oven which I would say is similar to the Casa2G100 (Approx 500kg including Firebricks etc).
                                Do you think a wooden stand would be adequate?
                                Could you provide some additional pictures showing the top (prior to adding your oven) of your stand as I would like to see how to applied the top joints / support?
