Oven on the Terrace - Forno Bravo Forum: The Wood-Fired Oven Community
Oven on the Terrace
  • Oven on the Terrace
    Greetings my fellow oven enthusiasts.
    This is my 1st post in this forum so i will state my cause briefly.
    I would like to build an oven out of firebricks on my terrace( for the lack of backyard). In the following images I show the available space.
    My story:
    My dad built that "base" 15 years ago and the funny thing is a was right there "helping" him (I was 10y.o.) Ah Good memories.
    A couple of years ago i entered the world of pizza making (as a college student) I made the best pizza I could in my electric kitchen oven. But now I want to take it up a notch (or a lot!)
    The big question is:
    Do I have enough room for a decent small oven?
    What expansions should I make?
    That is all for now.
    More questions may occure! Until then happy pizza making to all!
    Re: Oven on the Terrace
    I don't see any pictures yet, so, any response is premature
    To start, download and read the Pompeii oven plans, (Add to cart and checkout for free. The section describing the oven stand will give you an idea of the space you need.
    Lee B.
    DFW area, Texas, USA
      Before I check them I shall upload some renders I've made in SU8 These are accurate dimensions.The last picture is from a early rectangle model that was rejected.The circular base of the dome oven was made with angled firebricks, trapezium shaped with dimensions B=6cm, b=4cm, height=11cm length=22cm
      http://i738.photobucket.com/albums/x...g?t=1304097876
      http://i738.photobucket.com/albums/x...g?t=1304098140
      http://i738.photobucket.com/albums/x...g?t=1304098176
        Thank you for the tip. I will study the pdf with joy!
        I have some fears about the proximity to the oil storage though.
        Could you tell me which of the following materials are suitable for casting the front arch of the oven because I will not make it out of firebricks
        What extra materials will I need?
        The steel fibre-pins
        http://www.mathiosrefractories.com/2.../237/index.htm
        the castables
        http://www.mathiosrefractories.com/3.../223/index.htm
        the cement and agregates
        http://www.mathiosrefractories.com/3.../222/index.htm
        Thanks.
