Insulating hearth - Use firebricks instead of vermicrete? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Insulating hearth - Use firebricks instead of vermicrete?
    Hi everyone,
    My vermiculite/portland cement mix insulating hearth layer is thinner than I expected (2.5"). Instead of pouring another layer of the vermicrete, would an extra layer of firebricks work instead?
    My setup would be like:
    -2.5" vermiculite/portland cement
    -4" firebrick layer
    -4" firebrick layer (oven floor)
    Thanks in advance!
    Re: Insulating hearth - Use firebricks instead of vermicrete?
    "would an extra layer of firebricks work instead?"
    It does not substitute for insulation. I would add another 1 1/2 or 2 inches of vermicrete. Having said that, if yours is a typical Pompeii oven, the 2 1/2 inches of insulation with the firebrick hearth on top should work OK.
      Thanks Neil. I ended up pouring another 2 inches today after your advice.
