Door Ballast - Forno Bravo Forum: The Wood-Fired Oven Community
Door Ballast
  • Door Ballast
    Hi All
    My oven is more or less finished and is firing nicely, so time to think about building a door. I will probably will go with vermicultie sandwiched between sheets of aluminium or similar.
    I've read a few different posts where people refer to various types of "ballast" that they are using in their doors - rivits, washers and the like.
    Can someone explain the purpose - is it as simple is giving the door some weight so it stands upright?
    Thanks All.
    Poops
    Currently building first oven with red brick base
    FB plans plus Russell Jeavons book
    Re: Door Ballast
    I made my insulated door exactly as you describe, minus any form of ballast. I dont see the need, its 2 1/2" thick and stands on its own. Maybe it is the 1" aluminum framework I built under the outer aluminum skin that gives mine a bit more weight and makes it less tippy.
    RT
      Re: Door Ballast
      Hi,
      Where did you purchase your firebrick?
      Thanks.
