Floor heating problem - help! - Forno Bravo Forum: The Wood-Fired Oven Community
  • Floor heating problem - help!
    Hello all,
    I'm new in this forum and I'm a newbie in oven development as well . I have just built my first oven and i'm facing a problem that I'm unable to get above 50 degree Celsius on the oven floor. The doom is heated up well but the floor doesn't heat-up. I'm using natural gas burner instead of wood. I burnt fire for more than 2 hours but couldn't get the baking temperature on the floor.
    Can someone guide me to a fault finding direction so that I could find out what's going wrong with my oven?
    Thanks & Regards,
    Ahmad
    Re: Floor heating problem - help!
    First question is, do you have a layer of insulation under the hearth (floor) bricks ?
    Second, is this a new construction and therfore not fully cured yet ?
      It sounds like an accident waiting to happen using gas.
      The fire needs to be in contact with the floor of the oven for it to get hot enough.
        Hey
        Go to Forno Bravo home page. In "Commercial Ovens" go to "Compare" then downlad the pdf compare sheet. Compare your design with the right oven design. The problem of floor not heating enough is mentioned there.
        I forgot who said that.
          Well thats interesting.
          Forno Bravo discourage gas burners and discussion of them on the forum, yet they sell a gas burner model....
            The gas system's that are used in commercial ovens have the required safeguards to keep them from blowing up. A consumer gas burner stuck in an oven is not the same thing.
              My bet is, the dome is too high internally. What height?
                Coals maybe. Remember that flames stand up, and heat rises. What the ideal scenario should be, is the flames should be rolling around in the oven, and heating everything, inc the floor.
                  My bet is that the oven still contains moisture. It is a new one isn't it?
                    Yes, the floor bricks are insulated.
                    Yea, it's a new oven and it might still have moisture in it. The bricks had soaked a lot of water while I was dipping 'em for construction.
                    But I was thinking it should be cured after 3 drying fires.
                    Thanks & Regards,
                    Ahmad
                      OOO your comment worries me a little. I can never make my gas burner in contact to the floor
                      By referring to accident, do you mean it could blow up? I have given the oven breath hole and an exhaust as well.
                      Regards,
                      Ahmad
                        I think you are right david. My oven is still new and there might be a lot of moisture in the bricks. Even though, when I closely looked at the floor, I can still see the moist bricks.
                        I'll surely come back when my oven floor is dried out and will share my experience.
                        Thanks & Regards,
                        Ahmad
                          I'd like to share another thing that my gas burner is not the ideal one. Fornobravo states that the best gas burner is the one with a very large flame rather my burner has got many small flames .
                            Will be interested in hearing if that burner will heat that oven to the required temps once it's dried out. What size is it?
                              Sounds like the burner is a gas ring that is used for boiling a kettle or something?
                              Edit:-
                              I found this old thread about how many BTU's you need to heat an oven to pizza temps.
                              http://www.fornobravo.com/forum/f6/h...r-my-2181.html
