Brick Question - Forno Bravo Forum: The Wood-Fired Oven Community
Brick Question
  • Brick Question
    Can I use this brick for any part of the oven I am constructing? Particularly in the hearth or the dome.
    Re: Brick Question
    Nowhere with heat, but anywhere else is fine.
      Re: Brick Question
      It is fire brick that I received from a landscaper. He told me that he used this type for fireplaces. My main concern is with the holes.
        Re: Brick Question
        I'm using them for my oven stand, will do a double brick in places to support the 2nd slab, from there oven slab, oven floor insulating layer and then oven floor will go on top of that
        basically a house brick is it?
        Damon
        Build #1
        Build #2 (Current)
          Re: Brick Question
          You need something that looks like this for the dome and cooking floor. Just make sure they are clay and not concrete.
            Re: Brick Question
            "It is fire brick that I received from a landscaper. "
            There is a difference between a "fired brick" and a "fire brick".
