My Brush is stripped - Forno Bravo Forum: The Wood-Fired Oven Community
  • My Brush is stripped
    Hade it for a month now from Bravo and the darn thing has stripped and wont hold the brush any longer. Any ideas how to repair?
    Re: My Brush is stripped
    could you post a picture?
    Follow my build Chris' WFO
      Add a screw. drill a pilot hole through the brush head and handle then put in a screw.
        I thought that the brush had to be able to pivot left and right. If I screw it in won't it prevent teh ability for the brush to do that? I guess it ultimately wouldn't matter.
          You could also run a through bolt. Then you could still have your swivel.
            Just drilled a bolt with a nut on. It's amazing as you try to reproduce what was before you forget that what was before may not be necessary
