Decisions..Decisions.. - Forno Bravo Forum: The Wood-Fired Oven Community
  • Decisions..Decisions..
    Looking for a pizza oven after trying pizza from an oven my cousin built.. I dont want the hassle and time of building one and would like a prebuilt.. Wondering.. Will I get the same heat retention from say and Andiamo oven versus a non metal housing one like a Primavera or Toscana? Also, if I do get a larger, heavier oven such as the Toscana, will I be able to lift it up with an engine lift?
    Thanks!!
    Re: Decisions..Decisions..
    Anyone one from FB can correct me here but the metal housing on the Andiamo probably does not significantly increase your heat retention...infact I would venture a guess that you could easily touch the top of the Andiamo while fully fired just like you can touch the top of a Primavera...I think the metal just allows for a sleeker profile rather than heat retention...I used a 2 ton engine lift with a 79 inch reach-up for my Primavera 70 and it worked great.
