Add a grill grate to a FB Fireplace? - Forno Bravo Forum: The Wood-Fired Oven Community
  • Add a grill grate to a FB Fireplace?
    Has anyone ever fitted an FB fireplace with shelf supports on either side of the firebox, so that a (custom-made) iron grate could be slid in, over the coals, at a couple of different levels? Since the walls are straight, as opposed to angled as in some fireboxes, it would seem to be a possibility.
    Re: Add a grill grate to a FB Fireplace?
    Google Original Tuscan Grill........
      Thanks, buckeye, I do have a Tuscan grill, but I find it to be a bit wobbly and the support system takes up a lot of space. My thought was to bolt some shelf supports into the firebrick in 3 positions, on either side. Say, 6, 9, and 12 inches above the firebox floor, then get a local welder to make me a grate out of cast iron (probably best to make 2 of them). Before I dive into this, I wanted to run it past some of the pros. Old Sunset how-to books from the 50's and sixties hint at such dual-purpose use of a fireplace.
        Hi Brigit,
        Thank you for your post and question. We do not recommend that you drill holes in your fireplace. Also, the FB outdoor fireplace is not designed to be cooked in.
        Amber
          This seems an easier solution
          $86 at Amazon
