Super duty brick for floor - Forno Bravo Forum: The Wood-Fired Oven Community
  • Super duty brick for floor
    I am building a 42 inch Pompeii oven have built base and poured a 3.5 inch plicast 3000 insulated floor. When I went to pick up my medium fire brick they had 12x12 super duty brick and I thought hey that would be good for the floor ( less joints) then got home and I am now worried if the super duty will be to reflective per sey and cause me heat issues ..... Thoughts? Or just paranoid !!
    Re: Super duty brick for floor
    Super Duty brick should work fine. They will not reflect more heat. Super Duty brick are slightly denser then medium duty brick, and will take a little longer to heat up and cool down, but I feel the increased heat resistance, and thermal shock resistance more then make up for this. In the ovens we build, we use nothing lower then high duty materials, and try to upgrade to superduty whenever possible
      Originally posted by bpn1112 View Post
      Or just paranoid !!
      Correct.....
        My whole build is done with super duty, 65% alumina bricks, they were surplus from a steel mill. The only issues I had with super duty is they are tough as #$%* and hard on diamond blades but since you using for the floor with min. amt of cuts this should not be an issue. Use what you got and move on.
          Well I let paranoia get the best of me and decided on the medium duty for the floor . Thanks for the response tho , after reading a bunch more forum post I weighed the ease of using of laying the 12x12 to the length of heating up time it may cause and went with the medium duty. Here is pic of where I am at now.
            I'm using a super duty tile (61x61cm!) since I'm doing zero cutting for my oven, I thought worse case if the floor gets to hot I'll just buy a few pizza trays and once the bottom of the pizza is cooked I can put it on the tray to finish cooking.
              Another oven myth, they only get as hot as the fuel you chuck in will let them get.
