Looking For Advice Re Oven Floor Insulation - Forno Bravo Forum: The Wood-Fired Oven Community
  • Looking For Advice Re Oven Floor Insulation
    hi guys,
    im new to the forum but im being reading a lot lately looking for tips and learning different methods to build ovens..
    i already started building my oven and need some advice for the insulation of the floor..
    my first idea was to just use a layer of glass and rock sea salt and on top of it another layer of refractory mortar..
    then on top of it would place the alumina bricks...
    although now i bought the ceramic fiber blankets to insulate the dome and since i have spare i was wondering if i should also add one layer of ceramic fiber on top of the rock sea salt... to add extra insulation...
    so basically my question is if i should just go with
    glass/rock sea salt/refractory mortar/alumina bricks
    or
    glass/rock sea salt/ ceramic/refractory mortar/alumina bricks.
    what would you recommend?
    thanks in advance for your help.
    Fed.
    Re: Looking For Advice Re Oven Floor Insulation
    Originally posted by Fed View Post
    hi guys,
    or
    Fed.
    Don't put salt anywhere in or near concrete. It is corrosive and will do little as insulation.
    Glass is not a great insulator either...but it's better than putting the brick in contact with the concrete slab.
    Go the standard perlite/vermiculite concrete mix or ceramic board.
    Old World Stone & Garden
    John Ruskin
      thanks for your reply.
      the problem i have is that materials are really hard to find down here..
      i had to order most of the materials from manila..
      so i cannot get perlite/vermiculite or ceramic board... although i have the ceramic blanket..
      should i use the ceramic blanket on top of the glass then?
      thanks.
      Fed.
        See if you can locate materials that davids suggested, in the other thread were you asked this same question.
        John Ruskin
