Mortar recipe - Forno Bravo Forum: The Wood-Fired Oven Community
Mortar recipe
  • Mortar recipe
    Hi all, looking for some mortar recipe advise.... I have the refractory cement and sand but don't really know what ratio to mix them... This would be used to hold the bricks together.
    Secondly, I then need a recipe for the mortar with added perlite, to clad the brick dome.
    Regards
    Phil
    Re: Mortar recipe
    Regards
    Phil
    For mortar use 4:1
    For cladding are you trying to add it for strength and thermal mass or for insulation?
      Re: Mortar recipe
      Or apart?.....
      Welcome Phil.
        Re: Mortar recipe
        After the dome is built I will cover with ceramic blanket then the mortar + perlite blend, it is this blend that I am unsure of.
        Thanks all...
        Phil
          Re: Mortar recipe
          Thanks all...
          Phil
          For the perlite insulation layer you want to use plain. Portland cement (refractory mortar is much to expensive) and perlite at 10-1 or 11-1 you will need about 3 parts water to mix it. It will perform better if you can get some vermiculite to mix in at near 50-50 with the perlite but it is not necessary, should you get some vermiculite keep the overall ratio of 10-1 insulator to Portland.
          It will want to slump and Behiver used a curved trowel and a form to follow - he made them up to work it and it seemed to be a good way to go
          Chip
