About to start and confused already!
  • #16
    Re: About to start and confused already!
    Gudday
    An angle grinder and diamond grit blade will go through block like butter.
    Dusty but quick
    • #17
      If you cut a groove into the block work with the diamond blade then you can just drop the angle iron into it. Allow a slight gap each end of the angle iron to allow for its expansion.
      • #18
        Originally posted by hlcr View Post
        so I got my angle irons - i know i'm supposed to take a piece off each side to make them sit flat on the blocks
        If you are talking about cutting the iron, they make a blade for your grinder. It throws off a ton of sparks but it cuts pretty easily.
        • #19
          You'll lose all the strength of the angle iron if you remove bits off the sides. Better to recess it into the block work IMO.
          • #20
            thanks, so you're all recommending I cut into the block rather than the angle iron - that's probably easier to do too...i''ll give it a go!
            • #21
              will any $89 from the big green warehse do the job? or does it have to be more robust?
              • #22
                You could just hack away at the top of the blockwork with a chisel, just aim the blows down the block not sideways.
                • #23
                  Thanks for all the tips! I went the angle irons in the end and had them adjusted at a steel fabricator - best $60 i spent )
                  Is there an optimum length for the chimney - does it depend on the size of the dome?
                  Also, is it recommended to use a fire-rated render over the insulated dome or can i use a normal render?
                  • #24
                    If you need fire rated render over the insulation you have built it wrong.....
