Confused - Forno Bravo Forum: The Wood-Fired Oven Community
Confused
  • Confused
    Do I put mortor on 1st row of arch bricks or lay them dry onto base then mortor them row 2 etc or will the arch fall over until I build the actual dome
    Re: Confused
    Mortar brick to brick - do not mortar to the insulation, just leave it dry. There is PLENTY of weight to keep it in place. I just re-read your post. The first thing you are going to build is the arch?
      Re: Confused
      Gudday
      The bottom arch brick should be mortared to the dome brick next it, on its side not the base. It's the same first row of dome bricks,mortared to each other on the bricks sides, no mortar on the base. This way the dome and arch are able to float and expand and contract in the heating any cooling of the oven.
      An exactly like Les said
        Re: Confused
        Thanks COBBLEDAVE & LES
        Less confused now onward & upwards
        will post pix soon
          Re: Confused
          kitchen area so far WFO in background
            Re: Confused
            Its going to be a very small oven then?
              Re: Confused
              Are you planning on cantilevering your supporting slab?
                Re: Confused
                Gudday
                Now that would be a big idea
                  Re: Confused
                  may be this is a better look at base to take a 36 " and yes front will be a bit of a canterlever
                    Re: Confused
                    that should shut them up
                    joe watson
                    My Picasa Web Album
                      Re: Confused
                      And the challenge is......? cantilevers are easy peasy.
