Barrel vault?
  • #16
    Re: Barrel vault?
    Was I supposed to end the bricks at the door opening or take it out one more brick? I need to mortar and install the rebar in my cinder blocks before starting the arch, do I use regular mortar mix to for the cinder blocks and regular cement mixture to fill in the blocks or do I need to use a high temperature mix? I am referring to the cinder blocks that will support the side and back walls.
