what to use under anchor plate - Forno Bravo Forum: The Wood-Fired Oven Community
  • what to use under anchor plate
    Do I need to put any type of high temp. caulk between anchor plate and bricks for the chimney tube? Do I need to warp the chimney tube with blanket?
    Thanks.
    Re: what to use under anchor plate
    I used some high temp caulk under my anchor plate, simply to avoid 'smoke leakage.' Honestly I am not sure that it is even necessary.
    I didn't wrap any of my chimney and I don't see the need for it. You are going to lose heat out of the chimney - blanket won't help with that!
      Thanks.
      I would recommend high temp caulk when attaching the base plate to the brick. I remember the plate warping a bit the first time I brought it up to temp. If your using double walled pipe, I wouldn't see why you would need to wrap it.
      Chris
      Link to my photo album:
        Nah I bought it but decided not to use it. Mine is simply dynabokted to flue vent and capping bricks cemented in place to make it look pretty. No smoke leakage what so ever
        Wrapping chimney I wouldn't unless there is a specific reason you want to.
        Cheers Colin
          Are your dynabolts stainless? I don't like the use of steel subject to corrosion.And the bottom part of the flue will get pretty hot. A standard dynabolt won't be around for too many years in this position I'd wager.
