Help, confused about oven isulation... - Forno Bravo Forum: The Wood-Fired Oven Community
  • Help, confused about oven isulation...
    Hi, my name is Jean, I was hoping someone could help me with some steps to insulating an oven. My oven size will be 48.5x47x37, I will be using heat stop 50 (thats whats available in my area). Do I put a layer of heat stop 50, then insulfrax, then another layer of heat stop 50, or can I just do the heat stop 50, with insulfrax, then stucco. If someone could give me the proper steps in insulating my oven it would be greatly appreciated. I will be using the oven mainly for pizza and roasting, I would need to have the oven hot for about 5 hrs at most. Thanks
    Re: Help, confused about oven isulation...
    Heat stop 50 is a refractory mortar dry mix. It sticks firebricks together. It's one of the best products for that. It's used because it has a high resistance to heat, and strength. It has no insulating value at all.
    Insulfrax is a brand name of refractory insulation, it comes as a blanket. Typically a couple of inches of this is used, then a layer of vermiculite or perlite concrete. These are the insulation.
    What goes on top of this is just for waterproofing. There is no reason to use refractory mortar here, it's really expensive. Most builders just use a layer of ordinary stucco if they are building an igloo style oven.
    Good luck with your project. Let us know how it goes.
      Thanks dmun for a fast response, so I can use the heat stop 50 for the dome, then insulfrax for insulation, then waterproofing, such as stucco. Do I have to use vermiculite or perlite, or can I just double up on the insulfrax?
        Hi Jean,
        I just finished my Pompeii and shown on the forum:
        http://www.fornobravo.com/forum/f21/...-4-a-2045.html
        (permalink #8)
        I have tried to describe and show pictures of the build and insulation in the postings. Check them out as it gives hints as to problem areas especially when trying to plaster the insulation with vermiculite (or peerlite) cement.
        The later postings are at:
        http://www.fornobravo.com/forum/f21/...10-a-2119.html
        Hope this is of assitance to you.
        Regards.
        Neillís Pompeiii #1
        Neillís kitchen underway
          Nope, a double layer of insulfrax is just as good or better than a perlcrete layer. You may have to cover over the blanket with chicken wire to give your stucco layer something to grab onto.
            No problem with extra layers - just the cost....
            Where my oven had 2 layers I could put my hand on the top of the second layer when the oven was up to temp.
            Christo
            My oven progress -
            sigpic
              Thanks for all the help, I will keep u posted as to my progress.
              Jean
