Cutting concrete block - Forno Bravo Forum: The Wood-Fired Oven Community
  • Cutting concrete block
    I've got my stand all layed out and ready to pour the concrete inside the blocks but I need to get the blocks to lay flat after installing the angle iron. What is the easiest way (other than a wet diamond blade) to cut out for the angle iron so the blocks will lay flat?
    Re: Cutting concrete block
    Angle grinder and a masonary blade.
    Wade Lively
      My SkilSaw and a masonry blade made the job very easy.
      Ken
      Ken H. - Kentucky
      42" Pompeii
        But the easiest way is to set the angle iron outside the blocks and let your mortar make up the 3-5mm difference!
          I'll one-up you for an even easier route. Just sit the blocks on the angle iron and don't worry about any grooves or mortar thickness. Just let the blocks stick up a few millimeters.
          When you put the forms on the block stand for the hearth, make sure they are level (the blocks on the angle iron will stick up just a bit higher) and pour the hearth. No one will ever know. Shouldn't be any structural issues.
          That's how I'd do it if I had to do it again.
          Ken
          Ken H. - Kentucky
          42" Pompeii
            Thanks guys. I tried the skill saw yesterday and the old blade I had on there broke and I'm having a hell of a time trying to take off what is remaining on the shank. The blade I had on my angle grinder was for metal. I will go out and buy some new blades and continue.
              Unfortunately I am going the dry fit route so there isn't any mortar gap to make up the difference.
                Home Depot has started carrying good and cheap diamond blades for cutting brick, block and stone. They are a lot faster and easier than the old fashioned black masonry blades -- and not that much more expensive. They work really well at first when they are still sharp, so cutting block is a breeze.
                  Or you could just leave them out in the breeze .
                  No, really, get the diamond blade for the angle grinder. It's worth the money, and you'll use it a lot. And buy a good face mask while you're there. Big Dust Alert.
                    What size Angle Grinder you guys using...I bought a 4 inch and couldn't do much with it.
                    Tony
                      I got the 4 1/2. The extra quarter inch of depth really helps. Also, the diamond blades don't wear down a quarter inch per cut.
                        I always use a Skill saw and a full size blade. I am part of the "buy a cheap one and kill it" clan.
                          I have a 4" angle grinder so I'll pick up a blade on the way home from work and give it a try. Since the angle iron is 2" the 4 " should do the trick.
                            Make sure you get a metal blade for the angle iron, not a masonry blade! You can power your way through angle iron with the wrong blade, but it ruins the blade and is a big mess.
                              I meant mortar (or stucco) to the face of it when you finish the oven - the face does not need to be smooth - the block stand is just to raise the oven, but you are well on your way, no worries.
