Firebrick suitable for pizza ovens
  • #16
    Re: Firebrick suitable for pizza ovens
    Re: firebrick
    I was a potter for 20 years, built many kilns. I rarely used mortar, when planning I ordered wedge-arch-key brick. I'm in Oregon now and haven't been able to find a supplier for these shapes to allow building of a dome from refractory, (fire brick).
    • #17
      Tapered firebricks are used in various kiln and furnace applications, and the last time I looked were available in three angles to form three different radii. They are a specialist refractory item, and very expensive. Oddly, different angles have different costs. They are usually available in medium and high duty firebrick. Your local Harbison-Walker distributor should have them.
      Once you see the prices, you may want to cut your own.
      • #18
        Originally posted by WG Firebrick View Post
        Thanks dmun. The shapes as illustrated are beyond our manufacturing capabilities.
        Interesting....My oven is actually comprised of 15 cast firebrick pieces.
        9 identical blocks that form the soldiers and lower dome.
        1 dome piece
        2 opposite side blocks at the entry
        1 lintel
        1 transition to chimney
        1 chimney section with damper
        I've always wondered why this would not make a good kit for the homebuilder. Add stand, hearth and a FBmix mortar!
        • #19
          Originally posted by s.smilove View Post
          Re: firebrick
          Wedges and arches are something we do have the capability of making. We used to supply them to the steel industry. Here's a link to a two sizes that are available. Those produced here are low-duty and not terribly more expensive than straights.
          • #20
            This is Great! I've never seen low duty tapered firebricks, let alone affordable ones. Tell me exactly what I'm looking at here:
            Are these two different tapers alternating, or one taper alternating with standard firebrick? Do you have an angle or dimensions on the two tapers?
            Thanks.
            • #21
              That brick would be easy to build a 31" oven with, huh? Is there room for mortar between them?
              GJBingham
              • #22
                Better yet can we specify a reasonable angle?
                --mr.jim
                --mr.jim
                The real art of conversation is not only to say the correct thing at the right time, but also to leave
                unsaid the wrong thing at the tempting moment.
                • #23
                  There are two sizes in the photo. The first is a No #2 Arch. It measures roughly 8-1/4 x 4 x 2-3/8 to 1-5/8. The second is a No #1 Arch that measures 8-1/4 x 4 x 3 to 2-5/8. The radius shown was achieved by alternating the two sizes. Using just the No #2 Arch approximately an 18-inch inside radius can be achieved.
                  In fireplace construction we recommend mortar joints of 1/8-inch for firebox construction. Using a similar joint in the arch shown would add a bit to the overall size, but I wouldn't think it would be significant.
                  There are a couple standard industry angles. One of them is likely close to something reasonable for pizza oven use. What's most advantageous?
                  • #24
                    Can you post your list prices for the bricks? It will give a perspective on "not terribly more expensive....thanks!
                    • #25
                      Freight is a huge factor in the price of low-duty firebrick, but I would expect the two arches to be in the neighborhood of $1.20/each in pallet quantities if sourced through a masonry supply dealer moving material in truckload quantities.
                      If they were to be mixed and matched on a pallet and drop shipped to a private residence the price could be as high as $5-7.50/each depending on location. The difference being freight, and convenience.
