chiminey . door - Forno Bravo Forum: The Wood-Fired Oven Community
chiminey . door
  • chiminey . door
    If the door is installed before the chiminey . how would the oven get a draft if the door is closed?
    boclala
    Re: chiminey . door
    It doesn't - the door is there to retain the existing heat.
    Les...
      Re: chiminey . door
      If you have the door closed to keep the heat in, then you will obviously have no fire. Good for smoking your food though.
      Put the door on the wrong side of your chimney and you will not be able to keep the heat within your dome!
      Neillís Pompeiii #1
      Neillís kitchen underway
        Re: chiminey . door
        Essentially two ways to cook with the oven. Door stays open for cooking with the fire going (ie pizza). Once the fire burns out or is removed, the door is used to retain the heat for hearth style cooking (ie, bread, roasts, etc)
        Mike - Saginaw, MI
        Picasa Web Album
        My oven build thread
          Re: chiminey . door
          Ok to answer your question if you need to control burn an adjustable vent can be added to the door at bottom to slow down air flow to reduce burn. This is accdording to FB build instructions.
          The only time I could imagine wanting to do this is for smoking.
          like chicken...
          My 44" oven in progress...
          __________________________
            Re: chiminey . door
            Indeed! WFO's are great smokers!
            My thread:
            My costs:
            My pics:
              Re: chiminey . door
              I always use the damper in the door when cooking.....I never thought about it but I always put my door back on when cooking pizzas too! Guess I didn't know any better??
              When roasting I will also dial back the chimney damper for fire control and wood conservation and smoking too.
              Are most Pizzas cooked without a door?
              DUH...better try that for more flames!
              still, I think the door allows me to keep the oven hotter when I want.....less cold air rushing in unabated?
              still crazy after all these years.....
                Re: chiminey . door
                Well, put me in for a third way as I'm always right between these two....
                ....door on oven, fire burning inside. Hotter for pizza, cooler for the roasting!
                  Re: chiminey . door
                  Make up your mind SJ. Hotter or cooler? Pizza with the door out for me. I've yet to try cooking anything else with the fire burning. Any recommendations for a frist try?
                  GJBingham
                    Re: chiminey . door
                    ya know the more i think about it this contraption could be controlled like a BBQ. With this in mind the things my mind can imagine are endless.
                    like chicken...
                      Re: chiminey . door
                      I tried that dirty steak of Jim's the other day... Well actually I just flung a piece of meat on the glowing coals, no idea if its anything like what's on the video... BUT it was great fun! Tasted good, too. Nice and smoky.
                        Re: chiminey . door
                        Make up your mind SJ. ....................... Any recommendations for a frist try?
                        not much chance of that george!
                        nothing else with the fire burning????? Almost everything I've cooked is with a fire burning George!!!!
                        I think I've only pulled the fire out once for bread. Sometimes the more I read the less I know
