I was interested in SableSprings's comment about placing a waterproof barrier on top of concrete then adding insulation board. I have a 6" reinforced concrete hearth and I'm about to start cutting bricks. I intent placing 50mm approx 2" of CaSi board on top of the concrete with weep holes. I intend laying the oven floor on the brick edge for additional insulation ie 4.5" will be the brick height.
Given that this build is in Ireland I am concerned about having sufficient insulation.
Questions
1. Is this sufficient insulation?
2. Should I have 2" of cement/vermiculite and place the insulation board on top of that?
3. Does anyone have photos of the tile layer suggested to go between the concrete and insulation as a water barrier. I have some unused quarry stone tiles that were originally intended to cover an external step would they be suitable?
Thanks in anticipation of much needed advice!
Questions
