A familiar question of mortar in the UK - Forno Bravo Forum: The Wood-Fired Oven Community
  • A familiar question of mortar in the UK
    UK builders, I hope you can help!
    I'm about to buy from Yorkshire (Midland) Refractory: I'm getting ~230 bricks, some 50mm fibre board and some blankets.
    However: I'm really, really stuck/confused on mortars. Yorkshire refractories do a tub or ready-mix stuff, but it's air-setting rather than hydralically setting like the refmix FB sells. I've been told this isn't good for large gaps (like setting the dome and arches). So: do people use the lime/fireclay/sand/mortar mixes or is there some place good in the UK to get a better mix. Or is it okay to use the air-drying premixed stuff?
    Matt S, Cambs, UK
    42" Pompeii
    Pizza oven pictures - WIP!
    Pizza oven costs (so far!)
    Re: A familiar question of mortar in the UK
    Hi Matt,
    it doesn't look like you got much response from your enquiry.
    I hope that I'm not too late but in my build, I used the poor mans mortar, 1 portland cement, 1 hydrated lime, 1 fireclay and 3 brickie sand.
    I thought that the old Italian builders didn't have these modern refractory adhesives and I couldn't be bothered with the 2 types for the small joints and another for the thicker ones.
    When I was out at Paul Henderson's home finishing his Pompeii, his brickie was using these adhesives and they were terrible to use instead of what I used. Mine has been in use for over a year and no problems, Cheap, sticky, easy to use and no need to use formwork apart from the last few courses.
    Check it out at:
    and follow the prompts.
    Neillís Pompeiii #1
    Neillís kitchen underway
