Why do so many restrauants cook at low temp - Forno Bravo Forum: The Wood-Fired Oven Community
  • Why do so many restrauants cook at low temp
    Greetings; On my path of study I decided to visit as many restrauants with WFOs. I was amazed to find that most run the oven well below 700 degrees. And the lower the temp the worse the pizza was (big surprise). But my newbie question is WHY do they run the oven at lower temps? My guess is that at lower temps it takes longer to cook and any idiot can do it without the risk of burning the pizza? Kindly advise...tim
    Re: Why do so many restrauants cook at low temp
    Maybe the ovens don't go any higher? Or they have lower temps so that other foods can be cooked in the same oven - lasagne for instance. But your explanation sounds just as likely...
      Or maybe they want you to buy more drinks whilst you're waiting.
      If you are half tanked when you finally get it/them, then maybe you won't taste the poor pizzas!
      They could also be saving wood?
      Their insurance company could have a say if they use high temperatures? OR
      they simply don't know the difference!
      Neillís Pompeiii #1
      Neillís kitchen underway
        Most of the "brick oven" places around here have gas fired ovens, that at the most burn a little wood for decoration. And yes, lower temperature = lower skill needed for workers.
          Tim
          I think dmun hit the nail right on the head with "lower temperature = lower skill"...being one who is giong into such a business with my wife...staff training will be a huge issue...teaching them to toss a good base is one thing but...to teach them to manage such pizzas in an environment as potentially unforgiving an environment as a 800F oven is another...if you turn your head too long it is toast!!!
          Best
          Dutch
            Greetings; Many thanks for all the interesting and kind thoughts. I had one user contact me privately and tell me that the 'real' reason is that the restrauants are 'cheaping' out. That is to say, they run the oven cooler because of the cost of wood. Less wood = less cost. And finally, (I could not resist). It appears there are a number of 'half-baked" reasons to run the oven on the cool side.
            tim
              I think the answer might be in the fuel consumption. At the higher pizza temps we use the oven burns wood up pretty fast and the maintenance of the high temp, for a restaurant which is open for hours, would be considerable.
                It may also be the local market. We had a coal fired pizza place open a few months ago that started with 700+ temps and made pizzas very much like some famous NYC joints. When the local press reviewed the place after a couple months, the owner was reported as having lowered his temps as too many customers were sending back the slightly charred pies as "burned". The problem was compounded by the fact that he was doing thin crust pies rather than the fat boys that are more popular here in upstate NY. hopefully they will return to the original plan and let the customers catch up though that is a tough play for a new place.
                  Boy, what I wouldn't give to get a "burned" pie at a commercial place around here. Seem like EVERYTHING served up this way is very un-appetizingly undercooked.
                  We were actually thinking of ordering one "well-done" next time we eat pizza out.
                    As I tell my young boys (6,4 and 2). Our WF pizzas are never burnt just "over carmalized" for those times when I get slightly distracted while tending the oven.
                    Dick
                      Dick
                      Remember also that the "added" Carbon settles the stomach and removes impurities
                      Phill
