granite oven? - Forno Bravo Forum: The Wood-Fired Oven Community
granite oven?
  • granite oven?
    I was wondering if a oven could be built with granite cobblestones. They are very old and very dense. I want to put them to good use, but was worried about them exploding if heated. I am a total newbie.
    Re: granite oven?
    Hi...
    I've tried MARBLE as the hearth and it did not crack or explode (300C?)
    i was satisfied, i thought also about granite but i didn't
    try it i have the feelings that it will work
    the thermal conductivity of the MARBLE is around 2.5 W/mK
    and for the granite is 1.7 to 4 so they hold a good amount of
    heat.
    good luck
      Re: granite oven?
      Originally posted by Ammora View Post
      Hi...
      heat.
      good luck
      also check this out
      YouTube - Can heat crack granite? - Granite Shorts Ep.2
