Vent, Arch and landing materials
  • Vent, Arch and landing materials
    Hello All.
    I have read conflicting information on Suitable materials for the Arch Vent area and Landing.
    I was hoping i could use red clay bricks for the Arch and vent structure/flue and the landing in front of this area as well as normal portland brick mortar?
    The floor of the Vent area i was going to use firebricks but would then put clay bricks in front outside the oven area is this ok.
    Also why are dense fire bricks used in the vent area (OUTSIDE COOKING AREA)? I can understand the heat reasoning but wont this allow it to wick heat from the fire/cooking area of the dome to the outside? to me the ideal would be insulating fire bricks.
    Regards
    Bart
    http://www.fornobravo.com/forum/f2/o...-nz-14012.html
    Re: Vent, Arch and landing materials
    Bart,
    no matter what and who you talk to about anything and every thing, you will hear different opinions and ideas.
    Outside of your hottest area, the dome and oven hearth, you can use different materials but they must still be suitable to withstand the conditions, heat, wear and hygiene.
    Some people even like to isolate their oven hearth/void with insulation between their landing and hearth, others don't worry unless they want max heat retention within the dome/oven.
    Provided that the material (in your case brick) is fired clay and not portland cement, it will be fine as it still gets hot but not as your hearth. These fired clay bricks/pavers are subjected to around 1200˚C during manufacture and our temps are at least below half of this.
    Neill’s Pompeiii #1
    Neill’s kitchen underway
      Insulating fire bricks are WAY too soft to use in this high traffic area. You are going to be dragging firewood, cooking utensils, tools over this floor, and you want it to be the same material as the hearth floor. This whole area gets really hot. I wouldn't use ordinary portland mortar here, and I wouldn't use red bricks unless there was a real reason to do so.
        ok granted that Insulting bricks are too soft.
        So Dense Fire bricks it is !
        but can a clays be used in vent wall and arch or only on the front arch as decorative cladding? surly if you *can* use red brick in the dome (yes i know its not best/recommended) it would be alright up front.
          Firebrick only needs to be used in areas of direct flame contact.
            I think you'd be fine to use red brick for sides and front of the arch. I like that look and wished I'd done that when I built my oven.
            When I put a big scary fire in my oven some flame does spill out and into the chimney. If you used firebrick for the top of the arch I think you'd be quite safe.
            Christo
            My oven progress -
            sigpic
              Hi, I have a few questions and I've included a photo.
              I plan to use polished concrete in the landing area directly under the flue and right up against the oven floor. Can I pour concrete (without bonding) right up against the firebricks? Or should I create a narrow thermal break between the concrete and the firebricks? If so, how?
              Can I use ordinary concrete mix or countertop concrete mix for this landing area? If so, does adding fireclay to the mix help? How about using castable refractory and polishing that?
              Thanks,
              George
              George
              My 34" WFO build
                I poured right up against on mine. I did not use concrete, I used plain mortar, the same mortar I laid the black brick with, on the theory that the aggregate in concrete mix might have a different rate of expansion than the rest of the concrete. The highest temp I have registered on the landing is less than 300 degrees FYI.
                  Then would it be all right to use mortar or homebrew mortar even though my landing will be 5.5" thick (3" board + 2.5" firebrick)? Can mortar be poured that thick and not crack?
                  George
                  George
                  My 34" WFO build
                    If it is runny enough to be poured, it will probably crack. Make it as dry as possible and it should be fine.
                      Thanks!! I'll use mortar and cure it properly.
                      George
                      My 34" WFO build
                        I just went and took some measurements. Mine is 4" thick and begins 9" out from the inner arch. Yours looks like it will be much closer to the heat, so I do not think adding fire clay would hurt.
                          Thanks again. I would definitely use homebrew in this case.
                          George
                          George
                          My 34" WFO build
                            I used a similar solid pressed brick too. It gives a great contrast against the standard fire bricks. Unfortunately I haven't finished the oven yet so cannot confirm durability yet!!
                            John
                            __________________
                            My Oven Thread:
                            http://www.fornobravo.com/forum/f8/j...-wfo-7911.html
                            The difference between a successful person and others is not the lack of strength, nor the lack of knowledge… but rather, the lack of will power.
                              I have a follow-up question regarding using home brew mortar as landing material right up against the oven floor.
                              Can I add Quikrete's charcoal color pigment to this homebrew? Do you think the high heat would have any effect on this home brew composition?
                              Would it also be a good idea to add small broken bits and chunks of firebrick as aggregate in addition to sand in the mixture?
                              George
                              George
                              My 34" WFO build
