Hi from nz - Forno Bravo Forum: The Wood-Fired Oven Community
Hi from nz
  • Hi from nz
    Hey there everyone,from Christchurch, New Zealand,been lurking for a while now,being a sponge to all the great info on here.
    Am about to start a venture into the wfo world,so excited.
    Wanted to do a brick oven but here in the south of the mighty NZ fire bricks are soooo expensive,hence i have opted for a modular which i have come across.
    cheers Tanz
    Re: Hi from nz
    Gidday, Yeah i'm from Chch also, Sorry didn't see your post before otherwise would have said hi.
    There some reasonable supply information here if you haven't read it yet already.
    http://www.fornobravo.com/forum/f2/b...s-nz-7192.html
    I'm also kinda shafted by the cost of bricks best i can find is about 4.95+gst
    i'm thinking of fire bricks for the floor and perhaps arch then the rest out of castable.
    How you getting on with your design?
    http://www.fornobravo.com/forum/f2/o...-nz-14012.html
      Re: Hi from nz
      Sounds like we are going to be doing a very similar oven,we have decided also to go with the firebricks on the floor and arch and a castable that we are getting from Canterbury Clay Bricks.
      We have dug out and boxed (we are doing a corner design)and hoping to lay concrete this weekend.
      Would be great to keep in touch.
        Re: Hi from nz
        yeah sounds good, Canterbury clay don't do castable, they sell pretty much everything although i don't know if they have that much in stock though. We are possibly looking at getting half to a full pallet from invercargil direct from the factory later in the year. sounds like your a head of us. I've got structural problems with an existing retaining wall and adjacent tree beside my site which i will need to sort out first, I'm looking at doing a base similar in concept to the Morgans wfo project http://www.fornobravo.com/forum/f21/...uild-6703.html
        But just a round dome style oven instead.
        Are you going to go geodesic tiles or for full cast. I haven't made up my mind yet.
        I'm looking at doing a 900 inside diameter, have you done a drawing up of yours ?
        Anyway keep us posted be interested in how you get on and yes would be good to keep in touch.
        Regards
        Bart
          Re: Hi from nz
          G'day guys.
          I did a pizza oven here with castable concrete, its much easier than a brick dome, and Im a brickie too....
            Re: Hi from nz
            Sorry my mistake in saying castable,i meant modular(we have changed our plans so many times it got confusing.Its about a 40 inch oven.
              Re: Hi from nz
              @Brickie
              How thick is your thermal mass? also looks a bit close to the edge on the sides how well did the insulation work there?
              @Tanz, Lol, I know what you mean i have so many paper models and drawings laying around i almost don't know whats what anymore... yeah their modular oven looks alright.
              What are you planning to do on insulation?
              So far we plan on using 100mm Perlite concrete under the firebricks and about 200mm on the outside but still deciding.
              Regards
              Bart
                Re: Hi from nz
                I have no issues with my oven, it takes about 1 1/2 to 2 hours to heat up and retains the heat for hours.
                Obviously each oven will be different in the way they perform.
                Just build one......
                  Re: Hi from nz
                  we are using 50mm silicate board underneath the oven and going to do couple of layers of insulation blanket on top.
                    Re: Hi from nz
                    Sweet yeah that will do the deed. did you pick that up from formans insulation?
                      Re: Hi from nz
                      yes from Formans
                        Re: Hi from nz
                        Hey Tanz, where did you get the insulating board from and how much$$$???
                        cheers rob
                          Re: Hi from nz
                          I am getting from Formans here in Christchurch.
                          There boards are'nt as big as the FB ones but thickness and temp capacity are pretty on par.They measure 610mm length x 300mm width x 50mm thick and will hold temp of up to 1260 degrees c.Price on these boards is $11.70+gst per board (I am getting 8).
                          Works out a cheaper for me to get 8 of these than one FB BOARD.And I was told I would need 4 of the FB Ones at about $115nz dollars each
                          They also have the kaowool or supawool.
                          Tanz
                            Re: Hi from nz
                            Dam that's a good price.
                              Re: Hi from nz
                              Soooo not gonna argue that,could'nt believe my luck,in saying that everything else is costly here.
