building my new 42 inch oven - Forno Bravo Forum: The Wood-Fired Oven Community
  • building my new 42 inch oven
    hi here is how to build a 42 inch oven in 45 seconds (turn sound on)
    http://www.youtube.com/watch?v=YGcBcLFlFM0
    Re: building my new 42 inch oven
    This video contains content from INgrooves, who has blocked it in your country on copyright grounds.
    Tried to look at your video, and it was blocked.
      42 inch is inside diameter, standard plans from forno bravo
      they are 2nd hand fire bricks same size as regular house bricks
      I used nearly 130 bricks in 1/2. that was sides dome and arch only not floor. The floor is 14 (300mm x 300mm) fire brick tiles cut to size b4 adding sides
        Video works Dmun ! Karangi dude has watched it
          yes layed on a mix of 50/50 sand and fireclay
          (make fireclay dust) ? put off cuts in cement mixer and mix they put your music on loud as mixer mixing bricks is very loud.
          The Tiles are 2 sizes 38mm thick or 50mm thick, I chose the 50mm.
          once layed on bed and sides are fixed in angle grind any high spots on joins
            Video can't be seen in the USA. Those who can see it are in Australia
              Confirmed on the blocking.
              "This video contains content from INgrooves, who has blocked it in your country on copyright grounds."
              If you notice, it says 'country' and Karangi Dude' is from Australia.
              My oven (for now):
              http://www.fornobravo.com/forum/f43/...ven-14269.html
