Its too cold for pizza she said. - Forno Bravo Forum: The Wood-Fired Oven Community
  • Its too cold for pizza she said.
    Soooooo, maybe I should build an outdoor fire place......
    The whole dimensions will be , 3M wide by 1.2M deep, 2.1M high.
    Im hoping the fire box to be about 1.5M wide by .9M high so lots of people can stand in front to get warm by it.
    The firebox will be 500mm high off the deck and will have a seat all along the front built into it.
    Im doing the opposite to my oven build which had brick quoins and rock fill, this will be rock quoins and brick fill.
    Its almost impossible to match any form of brickwork, so I always try to complement it rather than compete.
    Re: Its too cold for pizza she said.
    Heh, you should tell your wife that even -25 Celsius isn't too cold for pizza.
    Looking forward to your next masterpiece.
      Gudday Brickie
      Where have the "guardians" gone off your oven ?
      Regards Dave
        That pic was prolly pre guardian......
        Talking of which, I was wondering what I could use on a flat brick faced fireplace to add some zest?
          Some progress today.
          I couldnt get enough of all the face bricks I wanted so I did the base in solid reds.
          The face bricks I have got for the project are 150 year old hand mades.
            I used to have quite a collection of Hawthorn Bricks used them to build a few fountains and raised beds
            They look beautiful,yours is looking good did you get a pro in to help you?
              He's the pro.
                Dear Brickie,
                A wood-fired oven would work very well in cold climates, and it won’t have any trouble with snow and very cold temperatures. A modern wood oven is installed using high tech insulation, which holds the heat in when the oven is cooking and keeps the cold out. We have many photographs of ovens working in the snow on Fornobravo.com, and the because of the insulation, the snow never even melts on the outside of the oven enclosure.
                It is important that your oven is installed properly, using the insulation that comes with the Forno Bravo modular oven kits, and that it is installed with a waterproof enclosure. The Primavera and Toscana assembled ovens can also work in your your climate.
                Regards,
                Amber
                  "Its too cold for pizza she said."
                  Tell her that when it gets like this then it too cold for pizza:
                    No it's not!
                      Dear Amber.
                      The snow never melts off my oven either....
                      By cold we are talking 10 degrees c.....
                        Some more progress today, I filled it with concrete, tomorrow I can get a go at the brickwork.
                        The plum tree blossom was falling as I was doing it.
                          Some more progress on the fireplace this morning...
                            looks fantastic love the bluestones
                              Thanks....
                              This is the first brickwork Ive done in 12 months, Ive retired from laying, I sort of hit my use by date......
                              Opening size, 1630 wide by.......hopefully 950 high, this will keep with in the golden mean/ratio.
