outdoor grill design drawing / questions - Forno Bravo Forum: The Wood-Fired Oven Community
  • outdoor grill design drawing / questions
    I came across this nice looking design for an outdoor oven/ grill. It looks quite doable but I am wonder about the 4 inch drop between the edge of the grate and the entry to the chimney. Is there a purpose for this. I have see other plans that have the air entry to the chimney at the same level as the fire. Does this barrier increase heat or increase air flow ?
    Bruce
    Re: outdoor grill design drawing / questions
    Can you post a larger picture? Can't quite read the one that was posted.
    Thanks!!!
    My oven progress -
    sigpic
      Ok
      Hopefully this one is better
      Bruce
        Still kind of small
        Let me try one more time
          It must be me. I am trying to load this file as a PNG. It is a snapshot from a PDF. If it is still too small check this link
          http://www.lsuagcenter.com/NR/rdonly...CampStoves.pdf
          and look at Concrete stove #1.
          Bruce
            The PDF you linked to had two pages, one blank and one a disclaimer paragraph. The images were too small to read the dimensions. From what little I see, it is a convoluted air flow. And, how do you grill with an iron plate on top? Does that come off when you're grilling?
              You're right the drawing calls for a flat iron top - it's really a drawing for a camp stove I bet the thougt is to replace the flat iron plate with a grate.
              Without the flat iron plate - it would not draw up the chimney. I'd also bet it took a while to establish a good draw even with the iron plate.
              It took a while for the first page to fully upload but the first page is there....
              Christo
              My oven progress -
              sigpic
                Thanks christo. I'm going back to plan A for the BBQ. I have actually seen several plans for a "brick BBQ" with the chimney in the back. Your explaination makes perfect sense. I was considering using an iron plate to help redirect the smoke somewhat like an offset smoker. This should be a lesson to me. Stay with the KISS principle ( Keep it Simple, Stupid)
